Hello
does anybody know why bar graph doesn’t recordy any data ?
it says no data yet, everything else is working
best regards!
Do you mean Superchart?
What app/server/library versions?
Is raw storage enabled?
Yes superchart
I installed it like 2 weeks ago just hooked up hardware two days ago so it should be recent version.
How do I enable or check if raw storage is enabled?
It’s all in here…
The only thing to bear in mind is that if you try to change the server.properties file (or any of the other config files for that matter) via the web portal then these changes aren’t saved.
You need to edit them directly, and restart the server afterwards.
Pete are we talking about
enable.raw.data.store=true
All of the steps under “Enabling raw data storage”
Thanx Pete. I’ll try it tomorrow
