Blynk Local Server on Intel Edison Board
Hello Guys,
I need to use the Blynk as the local server, but I don’t know how to do it on Intel Edison board. I have checked the topics which related to this issue, but I wouldn’t help. Can someone give me a hand to do that? I need a clear explain.
Thank You
GTY
So i see that Edison supports Linux so i don’t see why you would not be able to use the normal github explanation.
It actually runs on Java (like me in the morning)… so anything that can run Java should be able to install and run Local Server. The little Linux devices (RPi, etc) are the most popular for their compactness, built in networking and price
Im doing the instructions however, i get an error message after i write the command
java -jar server-0.24.3.jar -dataFolder /path
it says unable to access jarfile server-0.24.3.jar
im using putty to access intel edison board. Please help me i got just a little time to do this
@heisst probably you in wrong folder where no jar.
