Blynk local server 0-36-4-java8
With this version of server all my ESP8266 do not connect, any ideas?
with that same server all my ESP8266 do connect.
and I guess that answer is about as helpful as your question. You might want to be a bit more elaborate (e.g. share code, description of situation etc.)
In the mean time: revert to an older server version until you’ve resolved the isseu.
My six ESP8266-12 all connect on latest local server.
It’s exactly what I did, returning to the old version the ESPs connect correctly
What is the prev. server version?
server-0.30.2-java8.jar
Use port 8080
New server moved to 8080 as default hardware port instead of old 8442.
Ok so I have to recompile everything with this new library?
probably better, but you could remap the external 8442 port to 8080 in your router.
