Blynk lighting control Pannel with Physical LCD
Hi All,
I am currently creating a menu system for my blynk controlled smart home,
I am having a struggle with implementing bridges(not really main concern at this moment.)
my main concern is i cant get my code to write a value to a virtual pin, and then have that virtual pin display said value in on the switch widget in the mobile app:
i am not a coder by any means, i have basically butchered together code to get things working as they should,
i am now hitting a brick wall and can’t seem to figure out how to get it to work.
Hardware:
1 x Arduino uno via usb,
1 x D1Robot LCD Shield
2 x nodemcu clones running DHT11 & relay boards.
code below:
> /* Comment this out to disable prints and save space */
> #define BLYNK_PRINT SwSerial
> #include <SoftwareSerial.h>
> SoftwareSerial SwSerial(10, 11); // RX, TX
> #include <BlynkSimpleStream.h>
> // You should get Auth Token in the Blynk App.
> // Go to the Project Settings (nut icon).
> char auth[] = "noneofyabeezwax";
> int vswitch1, vswitch2, vswitch3, vswitch4, vswitch5 , vswitch6, vswitch7, vswitch8;
> int switch1;
> // Attach virtual serial terminal to Virtual Pin V1
> WidgetTerminal terminal(V0);
> // You can send commands from Terminal to your hardware. Just use
> // the same Virtual Pin as your Terminal Widget
> BLYNK_WRITE(V1)
>   int pinValue1 = param.asInt();
>   vswitch1 = pinValue1;
>  BLYNK_WRITE(V2) // V5 is the number of Virtual Pin
>   int pinValue2 = param.asInt();
>   vswitch2 = pinValue2;
>  BLYNK_WRITE(V3) // V5 is the number of Virtual Pin
>   int pinValue3 = param.asInt();
>   vswitch3 = pinValue3;
>  BLYNK_WRITE(V4) // V5 is the number of Virtual Pin
>   int pinValue4 = param.asInt();
>   vswitch4 = pinValue4;
>  BLYNK_WRITE(V5) // V5 is the number of Virtual Pin
>   int pinValue5 = param.asInt();
>   vswitch5 = pinValue5;
>  BLYNK_WRITE(V6) // V5 is the number of Virtual Pin
>   int pinValue6 = param.asInt();
>   vswitch6 = pinValue6;
>  BLYNK_WRITE(V7) // V5 is the number of Virtual Pin
>   int pinValue7 = param.asInt();
>   vswitch7 = pinValue7;
>  BLYNK_WRITE(V8) // V5 is the number of Virtual Pin
>   int pinValue8 = param.asInt();
>   vswitch8 = pinValue8;
>    This program is designed to get you as close as possible to a finished menu for the standard Arduino Uno LCD/button shield. The only required modifications
>    are to add as menu items to the master menu (menuItems array) and then modify/adjust the void functions below for each of those selections.
> // You can have up to 10 menu items in the menuItems[] array below without having to change the base programming at all. Name them however you'd like. Beyond 10 items, you will have to add additional "cases" in the switch/case
> // section of the operateMainMenu() function below. You will also have to add additional void functions (i.e. menuItem11, menuItem12, etc.) to the program.
> String menuItems[] = {"Kitchen", "Stove", "Livingroom", "Bathroom", "Hallway", "Bedroom"};
> // Navigation button variables
> int readKey;
> int savedDistance = 0;
> // Menu control variables
> int menuPage = 0;
> int maxMenuPages = round(((sizeof(menuItems) / sizeof(String)) / 2) + .5);
> int cursorPosition = 0;
> // Creates 3 custom characters for the menu display
> byte downArrow[8] = {
>   0b00100, //   *
>   0b00100, //   *
>   0b00100, //   *
>   0b00100, //   *
>   0b00100, //   *
>   0b10101, // * * *
>   0b01110, //  ***
>   0b00100  //   *
> byte upArrow[8] = {
>   0b00100, //   *
>   0b01110, //  ***
>   0b10101, // * * *
>   0b00100, //   *
>   0b00100, //   *
>   0b00100, //   *
>   0b00100, //   *
>   0b00100  //   *
> byte menuCursor[8] = {
>   B01000, //  *
>   B00100, //   *
>   B00010, //    *
>   B00001, //     *
>   B00010, //    *
>   B00100, //   *
>   B01000, //  *
>   B00000  //
> #include <Wire.h>
> #include <LiquidCrystal.h>
> // Setting the LCD shields pins
> LiquidCrystal lcd(8, 9, 4, 5, 6, 7);
> void setup()
>   // Debug console
>   SwSerial.begin(9600);
>   // Blynk will work through Serial
>   // Do not read or write this serial manually in your sketch
>   Serial.begin(9600);
>   Blynk.begin(Serial, auth);
>   // This will print Blynk Software version to the Terminal Widget when
>   // your hardware gets connected to Blynk Server
>   terminal.println(F("Blynk v" BLYNK_VERSION ": Device started"));
>   terminal.println(F("-------------"));
>   terminal.println(F("Type 'Marco' and get a reply, or type"));
>   terminal.println(F("anything else and get it printed back."));
>   terminal.flush();
>   // Initializes serial communication
>   // Initializes and clears the LCD screen
>   lcd.begin(16, 2);
>   lcd.clear();
>   // Creates the byte for the 3 custom characters
>   lcd.createChar(0, menuCursor);
>   lcd.createChar(1, upArrow);
>   lcd.createChar(2, downArrow);
> //void loop goes here
> // This function will generate the 2 menu items that can fit on the screen. They will change as you scroll through your menu. Up and down arrows will indicate your current menu position.
> void mainMenuDraw() {
>   Serial.print(menuPage);
>   lcd.clear();
>   lcd.setCursor(1, 0);
>   lcd.print(menuItems[menuPage]);
>   lcd.setCursor(1, 1);
>   lcd.print(menuItems[menuPage + 1]);
>   if (menuPage == 0) {
>     lcd.setCursor(15, 1);
>     lcd.write(byte(2));
>   } else if (menuPage > 0 and menuPage < maxMenuPages) {
>     lcd.write(byte(2));
>     lcd.setCursor(15, 0);
>     lcd.write(byte(1));
>   } else if (menuPage == maxMenuPages) {
>     lcd.write(byte(1));
> // When called, this function will erase the current cursor and redraw it based on the cursorPosition and menuPage variables.
> void drawCursor() {
>   for (int x = 0; x < 2; x++) {     // Erases current cursor
>     lcd.setCursor(0, x);
>     lcd.print(" ");
>   // The menu is set up to be progressive (menuPage 0 = Item 1 & Item 2, menuPage 1 = Item 2 & Item 3, menuPage 2 = Item 3 & Item 4), so
>   // in order to determine where the cursor should be you need to see if you are at an odd or even menu page and an odd or even cursor position.
>   if (menuPage % 2 == 0) {
>     if (cursorPosition % 2 == 0) {  // If the menu page is even and the cursor position is even that means the cursor should be on line 1
>       lcd.setCursor(0, 0);
>       lcd.write(byte(0));
>     if (cursorPosition % 2 != 0) {  // If the menu page is even and the cursor position is odd that means the cursor should be on line 2
>       lcd.setCursor(0, 1);
>       lcd.write(byte(0));
>   if (menuPage % 2 != 0) {
>     if (cursorPosition % 2 == 0) {  // If the menu page is odd and the cursor position is even that means the cursor should be on line 2
>       lcd.write(byte(0));
>     if (cursorPosition % 2 != 0) {  // If the menu page is odd and the cursor position is odd that means the cursor should be on line 1
>       lcd.write(byte(0));
> void operateMainMenu() {
>   int activeButton = 0;
>   while (activeButton == 0) {
>     int button;
>     readKey = analogRead(0);
>     if (readKey < 790) {
>       delay(100);
>     button = evaluateButton(readKey);
>     switch (button) {
>       case 0: // When button returns as 0 there is no action taken
>         break;
>       case 1:  // This case will execute if the "forward" button is pressed
>         button = 0;
>         switch (cursorPosition) { // The case that is selected here is dependent on which menu page you are on and where the cursor is.
>           case 0:
>             menuItem1();
>             break;
>           case 1:
>             menuItem2();
>             break;
>           case 2:
>             menuItem3();
>             break;
>           case 3:
>             menuItem4();
>             break;
>           case 4:
>             menuItem5();
>             break;
>           case 5:
>             menuItem6();
>             break;
>           case 6:
>             menuItem7();
>             break;
>           case 7:
>             menuItem8();
>             break;
>           case 8:
>             menuItem9();
>             break;
>           case 9:
>             menuItem10();
>             break;
>         activeButton = 1;
>         mainMenuDraw();
>         drawCursor();
>         break;
>       case 2:
>         button = 0;
>           cursorPosition = cursorPosition - 1;
>           cursorPosition = constrain(cursorPosition, 0, ((sizeof(menuItems) / sizeof(String)) - 1));
>         if (menuPage % 2 == 0 and cursorPosition % 2 == 0) {
>           menuPage = menuPage - 1;
>           menuPage = constrain(menuPage, 0, maxMenuPages);
>         if (menuPage % 2 != 0 and cursorPosition % 2 != 0) {
>         mainMenuDraw();
>         drawCursor();
>         activeButton = 1;
>         break;
>       case 3:
>         button = 0;
>         if (menuPage % 2 == 0 and cursorPosition % 2 != 0) {
>           menuPage = menuPage + 1;
>         if (menuPage % 2 != 0 and cursorPosition % 2 == 0) {
>         cursorPosition = cursorPosition + 1;
>         mainMenuDraw();
>         drawCursor();
>         activeButton = 1;
>         break;
> // This function is called whenever a button press is evaluated. The LCD shield works by observing a voltage drop across the buttons all hooked up to A0.
> int evaluateButton(int x) {
>   int result = 0;
>   if (x < 50) {
>     result = 1; // right
>   } else if (x < 195) {
>     result = 2; // up
>   } else if (x < 380) {
>     result = 3; // down
>   } else if (x < 790) {
>     result = 4; // left
>   return result;
> // If there are common usage instructions on more than 1 of your menu items you can call this function from the sub
> // menus to make things a little more simplified. If you don't have common instructions or verbage on multiple menus
> // I would just delete this void. You must also delete the drawInstructions()function calls from your sub menu functions.
> void drawInstructions() {
>   lcd.setCursor(0, 1); // Set cursor to the bottom line
>   lcd.print("Use ");
>   lcd.write(byte(1)); // Up arrow
>   lcd.print("/");
>   lcd.write(byte(2)); // Down arrow
>   lcd.print(" buttons");
> void menuItem1() { // Function executes when you select the 2nd item from main menu
>   lcd.clear();
>   lcd.setCursor(3, 0);
>     lcd.clear();
>   if (vswitch1 == 1)
>    lcd.print("ON/off");
>   if(vswitch1 == 0)
>       lcd.print("OFF/on");
>     int button;
>       delay(100);
>     switch (button) {
>      case 2:
>      vswitch1 = 0;
>      switch1 = 1;
>      button = 0;
>      lcd.clear();
>      lcd.print("Turned Off");
>      delay(1000);
>         activeButton = 1;
>         break;
>      case 3:
>      vswitch1 = 1;
>      switch1 =0;
>      button = 0;
>      lcd.clear();
>      lcd.print("Turned On");
>      delay(1000);
>         activeButton = 1;
>         break;
>       case 4:// This case will execute if the "back" button is pressed
>         button = 0;
>         activeButton = 1;
>         break;
> BLYNK_READ(V1) // Widget in the app READs Virtal Pin V5 with the certain frequency
>   // This command writes Arduino's uptime in seconds to Virtual Pin V5
>   Blynk.virtualWrite(V1, switch1);
> void menuItem2() { // Function executes when you select the 2nd item from main menu
>   lcd.clear();
>   if (vswitch2 == 1)
>   if(vswitch2 == 0)
>     int button;
>       delay(100);
>     switch (button) {
>      case 2:
>      vswitch2 = 0;
>      Blynk.virtualWrite(V2,0);
>      button = 0;
>      lcd.clear();
>      delay(1000);
>         activeButton = 1;
>         break;
>      case 3:
>      vswitch2 = 1;
>      Blynk.virtualWrite(V2,1);
>      button = 0;
>      lcd.clear();
>      delay(1000);
>         activeButton = 1;
>         break;
>         button = 0;
>         activeButton = 1;
>         break;
> void menuItem3() { // Function executes when you select the 3rd item from main menu
>   lcd.clear();
>   if (vswitch3 == 1)
>   if(vswitch3 == 0)
>     int button;
>       delay(100);
>     switch (button) {
>      case 2:
>      vswitch3 = 0;
>      Blynk.virtualWrite(V3,0);
>      button = 0;
>      lcd.clear();
>      delay(1000);
>         activeButton = 1;
>         break;
>      case 3:
>      vswitch3 = 1;
>      Blynk.virtualWrite(V3,1);
>      button = 0;
>      lcd.clear();
>      delay(1000);
>         activeButton = 1;
>         break;
>         button = 0;
>         activeButton = 1;
>         break;
> void menuItem4() { // Function executes when you select the 4th item from main menu
>   lcd.clear();
>   if (vswitch4 == 1)
>   if(vswitch4 == 0)
>     int button;
>       delay(100);
>     switch (button) {
>      case 2:
>      vswitch4 = 0;
>      Blynk.virtualWrite(4,LOW);
>      button = 0;
>      lcd.clear();
>      delay(1000);
>         activeButton = 1;
>         break;
>      case 3:
>      vswitch4 = 1;
>      Blynk.virtualWrite(V4,1);
>      button = 0;
>      lcd.clear();
>      delay(1000);
>         activeButton = 1;
>         break;
>         button = 0;
>         activeButton = 1;
>         break;
> void menuItem5() { // Function executes when you select the 5th item from main menu
>   lcd.clear();
>   if (vswitch5 == 1)
>   if(vswitch5 == 0)
>     int button;
>       delay(100);
>     switch (button) {
>      case 2:
>      vswitch5 = 0;
>      Blynk.virtualWrite(V5,0);
>      button = 0;
>      lcd.clear();
>      delay(1000);
>         activeButton = 1;
>         break;
>      case 3:
>      vswitch5 = 1;
>      Blynk.virtualWrite(V5,1);
>      button = 0;
>      lcd.clear();
>      delay(1000);
>         activeButton = 1;
>         break;
>         button = 0;
>         activeButton = 1;
>         break;
> void menuItem6() { // Function executes when you select the 6th item from main menu
>   lcd.clear();
>   if (vswitch6 == 1)
>   if(vswitch6 == 0)
>     int button;
>       delay(100);
>     switch (button) {
>      case 2:
>      vswitch6 = 0;
>      Blynk.virtualWrite(V6,0);
>      button = 0;
>      lcd.clear();
>      delay(1000);
>         activeButton = 1;
>         break;
>      case 3:
>      vswitch6 = 1;
>      Blynk.virtualWrite(V6,1);
>      button = 0;
>      lcd.clear();
>      delay(1000);
>         activeButton = 1;
>         break;
>         button = 0;
>         activeButton = 1;
>         break;
> void menuItem7() { // Function executes when you select the 7th item from main menu
>   lcd.clear();
>   lcd.print("Sub Menu 7");
>     int button;
>       delay(100);
>     switch (button) {
>       case 4:  // This case will execute if the "back" button is pressed
>         button = 0;
>         activeButton = 1;
>         break;
> void menuItem8() { // Function executes when you select the 8th item from main menu
>   lcd.clear();
>   lcd.print("Sub Menu 8");
>     int button;
>       delay(100);
>     switch (button) {
>         button = 0;
>         activeButton = 1;
>         break;
> void menuItem9() { // Function executes when you select the 9th item from main menu
>   lcd.clear();
>   lcd.print("Sub Menu 9");
>     int button;
>       delay(100);
>     switch (button) {
>         button = 0;
>         activeButton = 1;
>         break;
> void menuItem10() { // Function executes when you select the 10th item from main menu
>   lcd.clear();
>   lcd.print("Sub Menu 10");
>     int button;
>       delay(100);
>     switch (button) {
>         button = 0;
>         activeButton = 1;
>         break;
> void loop() {
>   mainMenuDraw();
>   drawCursor();
>   operateMainMenu();
>    Blynk.run();
I’m reading this on a phone, so trying to see what you’re doing in your code is almost impossible without a pointer to the section in question.
However, if what you’re trying to achieve is this:
where the value of 29:40 is shown on the switch widget, then you have to use the setProperty command to change the onLabel and/or offLabel property of the switch widget.
Hi Pete,
so What im trying to accomplish, is have a little lcd control pannel to turn on and off my lights,
the menu is a template i pulled and ive tried to add the code needed for basically just changing the state of a Virtual pin from high to low(i understand Blynk.virtualWrite(V1,val)) should update the status of said pin?
so on the app i have a switch, i just need the switch to update its state when i change it in the code:
    >   lcd.clear();
    >     lcd.clear();
    >   if (vswitch1 == 1)
    >   if(vswitch1 == 0)
    >     int button;
    >       delay(100);
    >     switch (button) {
    >      case 2:
    >      vswitch1 = 0;
    >      switch1 = 1;
    >      button = 0;
    >      lcd.clear();
    >      delay(1000);
    >         activeButton = 1;
    >         break;
    >      case 3:
    >      vswitch1 = 1;
    >      switch1 =0;
    >      button = 0;
    >      lcd.clear();
    >      delay(1000);
    >         activeButton = 1;
    >         break;
    >         button = 0;
    >         activeButton = 1;
    >         break;
    > Blynk.virtualWrite(V1,switch1)
Assuming that this if/while/case statement combo is actually assigning a 1 or 0 to the variable switch1 then it should work.
Your earlier comment about Bridge problems makes me think that maybe you have multiple devices set-up in your app.
If this is the case then the switch widget on V1 needs to be assigned to the device that has the same auth code as the one you’re using in your sketch.
My bet is that you’ve connected your switch widget to a different device within the app.
Hi Pete,
i have checked it again and, authcode is fine, it would only be this device on its own app,
the other two devices 2 x ESP8266 each have their own app running,
hence the need for a central point to manage the Bridges from and to have a single app controlling all my devices,
however I can’t get that going until i sort out the issue with the Vpins not updating.
I can read the Vpin information on the arduino, I just can’t seem to write back to it.
IE i can pull the state of all the Vpins through to the lcd, Showing me whats on or off, i just cant change the state.
I don’t know if this has anything to do with it but i am using an Arduino UNO Via a PC to connect to Blynk.
You code snippet is full of process blocking delay() and while() commands… not Blynk friendly
Other then that, I am not understanding your question…
You can send vPin data from App to the Device via BLYNK_WRITE(vPin) functions, and the int data = param.asInt() command for integers… or other types using different data types.
And you can send data from the Device to the App with a Blynk.virtualWrite(vPin, data) command
Hi Gunner,
The only thing i can think of causing it not to work at this point would then possibly be the while and delay(),
I know i can get around the delay with a timer. I have no idea how to get rid of the while loop. As its needed to look for button presses.
Use fast timed polling that repeatedly looks for a press each time, instead of a blocking function the sits around waiting for a press.
Like in this example…
