Hello community this is abhishek
i have been working on the project which name called patient monitoring system which basically takes the health parameter of the patient ,it has 3 main sensors Spo2(MAX30100) and IR temprateremeter and last Blood pressure sensor and Main controller ESP8266 ,spo2 and IR tempmeter usually connects on I2c pins and blood pressure sensor interface with softwareserial pins its brief working
#include <Blynk.h>
#include<SPI.h>
#include <Wire.h>
//#include <SoftwareSerial.h>
#include "MAX30100_PulseOximeter.h"
#include <Adafruit_MLX90614.h>
#define REPORTING_PERIOD_MS 100
#define EspSerial Serial1
//SoftwareSerial portTwo(15, 13); //TX,RX
char auth[] = "zfdfML-j0uRZGO2OZMI5H87B1vUS1zSD"; // You should get Auth Token in the Blynk App.
char ssid[] = "Ajay_Home"; // Your WiFi credentials.
char pass[] = "Alph@##1307";
Adafruit_MLX90614 mlx = Adafruit_MLX90614();
PulseOximeter pox;
uint32_t tsLastReport = 0;
double temp_amb = 0;
double temp_obj = 0;
double calibration = 2.36;
int SpO2 = 0;
int i = 2;
char sbuffer[30], ch;
unsigned char pos;
unsigned char read1, read2, read3;
int Sys, Dys, Puls;
void onBeatDetected()
Serial.println("Beat!");
char mygetchar(void)
while (!Serial1.available());
return Serial1.read();
Serial1.begin(9600);
if (!mlx.begin()) {
Serial.println("FAILED");
for (;;);
Serial.println("SUCCESS");
if (!pox.begin()) {
for (;;);
pox.setIRLedCurrent(MAX30100_LED_CURR_7_6MA);
// Register a callback for the beat detection
pox.setOnBeatDetectedCallback(onBeatDetected);
while (i == 1) {
pox.update();
temp_obj = mlx.readObjectTempF();
SpO2 = pox.getSpO2();
if (millis() - tsLastReport > REPORTING_PERIOD_MS) {
Serial.print("bpm / SpO2:");
Serial.print(SpO2);
Serial.println("%");
Serial.print(tsLastReport);
Serial.print("Object temp = ");
Serial.println(temp_obj);
Blynk.virtualWrite(V3, temp_obj);
Blynk.virtualWrite(V4, SpO2);
if ((0 < SpO2) && (SpO2 < 95)) {
Serial.print("LOW");
else {
break;
delay(10000);
tsLastReport = millis();
while (i == 2) {
ch = mygetchar();
if (ch == 0x0A)
pos = 0; // buffer position reset for next reading
read1 = ((sbuffer[1] - '0') * 100) + ((sbuffer[2] - '0') * 10) + (sbuffer[3] - '0');
Sys = read1 - '0';
read2 = ((sbuffer[6] - '0') * 100) + ((sbuffer[7] - '0') * 10) + (sbuffer[8] - '0');
Dys = read2 - '0';
read3 = ((sbuffer[11] - '0') * 100) + ((sbuffer[12] - '0') * 10) + (sbuffer[13] - '0');
Puls = read3 - '0';
Serial1.println("*****************");
Serial1.print("SYSTOLIC:");
Serial1.print(read1, Sys);
Serial1.print('\n');
Serial1.print("DYSTOLIC:");
Serial1.print(read2, Dys);
Serial1.print("PULSE");
Serial1.print(read3, Puls);
Blynk.virtualWrite(V1, Sys);
Blynk.virtualWrite(V2, Dys);
Blynk.virtualWrite(V3, Puls);
// tsLastReport = millis();
else { //store serial data to buffer
sbuffer[pos] = ch;
pos++;
the issue is whenever I run this code, in blynk app " device connected" and "device is disconnected " getting this kind of message at the bottom of the app repeatedly
i do not know what to do I googled it I read many topics in community still I’m not getting proper solution if any one want to help please reply or you can contact directly to 1MS18TE400@gmail.com this mail …
