So,
I have a program that controls my clothes dryer on my Photon, it uses an lcd shield and Blynk for control.
Here’s the problem, if I use Blynk it will stop the photon from reading the on/off button. Any idea what could be happnening? I’ve set up a simple demo app that elicits the same behavior.
#include "blynk/blynk.h"
#include "LiquidCrystal/LiquidCrystal.h"
char auth[] = "authgoeshere";
int start_stop_button = A5;
LiquidCrystal lcd(2, 1, 6, 5, 4, 3);
// Blynk.begin(auth); //uncomment these lines to turn blynk on/off
pinMode(start_stop_button, INPUT);
lcd.begin(16, 2);
lcd.clear();
// Blynk.run(); //uncomment these lines to turn blynk on/off
lcd.setCursor(0,0);
lcd.print("Button");
int reading = digitalRead(start_stop_button);
if (reading == HIGH){
lcd.setCursor(0,1);
lcd.print(" pressed");
if (reading == LOW){
lcd.setCursor(0,1);
lcd.print("not pressed");
At first it works, then if I put the blynk app to write the button output to a5, the blynk button works, but the physical button won’t. Then if I have blynk write to a different output (say v1), the physical button won’t work. It will keep not working for some indeterminate number of resets of the photon. Eventually, the photon will start reading the physical buttons again. However, if I turn blynk off (comment out start and run lines), and reboot, the photon will read the physical button immediately. The same behavior happens in my dryer code too (which I’m happy to share, but it’s much longer, and much much harder to read).
It looks like your code is setting A5 as an input to read from the button, I assume you have an external pull up for this or it doesn’t need one.
You also say that you use Blynk to write to A5, so your trying to use A5 as an input and an output at the same time? A look at the how the Blynk app is configured might help.
Also in your main loop it looks like you are writing the lcd every time through the loop, it would be better to keep track of the old button state so you only write to the lcd when something has changed.
@pavel
I’m trying to get the button interrupt code to work, but it won’t compile. Build.particle just gives: testing_start_stop_button.cpp:83:42: error: 'digitalPinToInterrupt' was not declared in this scope
#include "blynk/BlynkSimpleParticle.h"
char auth[] = "auth";
WidgetLED led1(V1);
Blynk.begin(auth);
// Make pin 2 HIGH by default
pinMode(A5, INPUT);
// Attach INT to our handler
attachInterrupt(digitalPinToInterrupt(A5), checkPin, CHANGE);
void checkPin()
// Invert state, since button is "Active LOW"
if (digitalRead(2)) {
led1.off();
led1.on();
