Blynk IFTTT , ¿ possible to send push button like command?
Hello Blynk Community
I am connecting my room air freshener with google home, Ifttt and blynk. I am able to make the IFTTT part happen. But the only problem is I can either turn it on or off. I don’t know if it’s possible to send a pulse signal, I mean it turns on for few millisecond and then turns off automatically?
I am sending a PUT command, with application/json and in the BODY “[< < < 1 > > >]” . Is it possible to send a push button like command on the BODY part of IFTTT?
http://46.101.143.225/**108448ca79061c327/pin/D12
I am using a NodeMCU.
Thank you!
@Amantevez now that Blynk has things like the GPS widget is there really anything that you need from IFTTT?
@Costas Yes, I still need IFTTT so that I can control my home appliances with voice recognitions using google home.
Solved!
int ledPin = 12;     //responde a  GPIO D6 de NodeMCU
char auth[] = "***************************************";
char ssid[] = "*************";
char pass[] = "**************";
  if (digitalRead(ledPin) == HIGH) {
    delay (200);
    digitalWrite(ledPin, LOW);
Now the digital pin turns high whenever a request is made, but comes down to low state after 200 ms.
Aman, can you maybe help with the IFTTT part ? I use maker channel, ip instead dns name but whatever I try nothing works. http://blynk-cloud.com/XXXXXc746cb445daec3509eXXXXX/update/D4?value=0 works fine (although I also would like a push with this request)
Thanks in advance
