Blynk idea notes
I was thinking of the blynk server to leave a message to the people who see the application and share the project, it would be good to have notes to leave something written to the next people who see the project. I just looked to see if there was something similar and it seemed good idea
Have you tried the Terminal widget wit Input Line turned on?
All developments are stopped since 2018.
no, the truth is that I can’t ask you, where can I get information from?
Add the terminal widget to your project, ensure that “Line Input” is enabled, test the results and see if it meets your needs.
What more information do you need?
Thank you very much for the information, I will try, have a good day
It could be that when I leave the note in the terminal, if I put pause to blynk and then play, the message disappears, is there any way that it remains?
Probably not.
Maybe a text input widget linked to a value display or LCD widget may be a better option then?
When the text is passed to the lcd, a text does not enter the lcd, but I can use the text input as a place to leave a message, it hurts that the widget cannot be enlarged, the same thing happened with the lcd, that’s why the text or rather the full text is not accommodated on the lcd screen I think I’ll just have to use text input
