Hi, I’m using Pico W with HTTP to update datastreams to Blynk, Arduino IDE. One datastream works ok, but when I add a second (v1) it only updates the first. Snippet of my code, with i a simpple counter and led 1 or 0:
if (client.connect(host, port)) {
sprintf(s, “GET /external/api/update?token=%s&V0=%d&V1=%d HTTP/1.1\n”, BLYNK_AUTH_TOKEN, i, led);
client.print(s);
client.stop();
Thanks for any help!
@BasJPD when you post code to the forum you need to use triple backticks which look like this:
Not the characters that you used.
You’re missing the batch keyword between api\ and update?
Thank you very much, now it works!
I consulted the documentation for get multiple datastreams:
