Before creating the topic
- Search forum for similar topics
- Check http://docs.blynk.cc and http://help.blynk.cc/
- Add details :
• Blynk Library version
• Add your sketch code.Code should be formatted as example below.
Hi
my project arduino mega + 16ch relay module + ethernet shield, using for domotic.
i have created app with blynk and sketch for arduino is all perfect , now i wold using a ifttt , but i have problem because when send a comand with google assistant, the relè is forever on, instead the rele i use it as a button .
how can I send two commands simultaneously
example i say turn on the light ifttt send value=1 and value=0
i say turn off the light ifttt send value=0 and value=1
thank’s
