It’s happening again this time by
WidgetTerminal terminal();
When I enable and use it gets stuck in ping/ready. The serial monitor is the same as the first post.
Here’s the updated code with terminal enabled:
#define BLYNK_TEMPLATE_ID ""
#define BLYNK_DEVICE_NAME ""
#define BLYNK_AUTH_TOKEN ""
//LCD
//#include <avr/interrupt.h>
#include <Wire.h>
//Ultrasonic Easyuino API
#include <Easyuino.h>
using Easyuino::DistanceMeter;
//Defines and Pins
//Motor
#define motor1F 9
#define motor1B 6
#define motor2F 5
#define motor2B 3
//UltraSS
#define trigPinF 11
#define echoPinF 10
#define trigPinB 8
#define echoPinB 7
//DistanceMeter USSF(trigPinF, echoPinF);
//DistanceMeter USSB(trigPinB, echoPinB);
//LCD
//LiquidCrystal_I2C lcd(0x27, 16, 2);
// addr,en,rw,rs,d4,d5,d6,d7,bl,blpol
// addr can be 0x3F or 0x27
#define breaksecs 15 //break out
//GValues
boolean StartStop = false;
boolean BoxLoad = false;
int BHZz = 1000;
//Start of Blynk Code
#include <ESP8266_Lib.h>
char ssid[] = "";
char pass[] = "";
char ssid[] = "(2.4G)";
char pass[] = "";
#define NEOSWSERIAL_EXTERNAL_PCINT
#include <NeoSWSerial.h>
NeoSWSerial EspSerial(12, 13); // RX, TX
//#include <SoftwareSerial.h>
//SoftwareSerial EspSerial(12, 13); // RX, TX
// Your ESP8266 baud rate:
#define ESP8266_BAUD 9600
ESP8266 wifi(&EspSerial);
WidgetTerminal terminal(V15);
int Rsteer = 0;
BLYNK_WRITE(V3) {
Rsteer = param.asInt(); // assigning incoming value from pin V0 to a variable
int Speed = 0;
BLYNK_WRITE(V2) {
Speed = param.asInt(); // assigning incoming value from pin V0 to a variable
int Trigger = 0;
BLYNK_WRITE(V0) {
Trigger = param.asInt(); // assigning incoming value from pin V0 to a variable
int X = 0;
BLYNK_WRITE(V8) {
X = param.asInt();
int Y = 0;
BLYNK_WRITE(V9) {
Y = param.asInt();
int RunitsF = 0;
BLYNK_WRITE(V10) {
RunitsF = param.asInt();
BLYNK_WRITE(V15) {
String TempStringTerm = param.asString();
if (String("Stop") == param.asStr()) {
StartStop = false;
terminal.println("Stopping");
} else if (String("Start") == param.asStr()) {
StartStop = true;
terminal.println("Starting");
} else if (String("Full") == param.asStr()) {
BoxLoad = true;
terminal.println("Set to Full");
} else if (String("Empty") == param.asStr()) {
BoxLoad = false;
terminal.println("Set to Empty");
} else if (TempStringTerm.indexOf("Hz Set") != -1){
TempStringTerm.remove(0,6);
BHZz = TempStringTerm.toInt();
//End of Blynk Code
PCICR |= B00000100; //Turn on ISR for PD
PCMSK1 |= B00000000; //ISR PC for Pin A0 and A1 [No in use at the moment]
PCMSK2 |= B00010100; //ISR PD for Pin D2 and D4
pinMode(2, INPUT_PULLUP);
pinMode(4, INPUT_PULLUP);
//Start of Blynk Setup
// Set ESP8266 baud rate
delay(500);
//Blynk.config(BLYNK_AUTH_TOKEN, "blynk.cloud", 80);
Blynk.begin(BLYNK_AUTH_TOKEN, wifi, ssid, pass);
//Blynk.begin(auth, wifi, ssid, pass, "blynk.cloud", 80);
Serial.println("Done!");
//End of Blynk Setup
//Motors
pinMode(motor1F, OUTPUT);
pinMode(motor2B, OUTPUT);
//LCD
lcd.init();
lcd.clear();
lcd.setCursor(0, 0);
lcd.begin(16, 2); // 16 characters, 2 lines
lcd.backlight(); // turn backlight on
lcd.setBacklight(100);
lcd.print("Ready");
//USensor
USSF.begin();
USSB.begin();
MBrake();
void myTimerEvent() {
//Serial.println("Test");
Blynk.virtualWrite(V1, millis() / 1000);
if (BoxLoad) {
tone(A2, BHZz);
noTone(A2);
if (StartStop) {
//Serial.println("StartStop");
Blynk.syncVirtual(V0, V2);
//MDrive(1);
MRUnit();
//Blynk!
// to avoid delay() function!
HitCheck();
//End of Blynk
//MUnit(0,0,0);
void MBrake() {
digitalWrite(motor1F, 0);
digitalWrite(motor1B, 0);
digitalWrite(motor2F, 0);
digitalWrite(motor2B, 0);
void MUnit(int units, int throttle, int Steering) {
//terminal.println("Moving");
int countF = 0;
int countR = 0;
int pasF = digitalRead(A0);
int pasR = digitalRead(A1);
MDrive(0, 255 * constrain(throttle, -1, 1), Steering); // Jump Start Motors
delay(50); // Jump Starting
MDrive(0, throttle, Steering); // Set to main speed
if (abs(Steering) == 255) // steering only
while (countF <= units && countR <= units) {
switch (millis() / 1000) {
case breaksecs: //If code Runs for x number of seconds Break
units = 0;
break;
default:
if (pasR == digitalRead(A1)) {
countR++;
if (pasF == digitalRead(A0)) {
countF++;
} else // Forward and backward with some steering
while (countF <= units || countR <= units) {
units = 0;
break;
default:
if ((millis() / 1000) % 2) {
switch (constrain(throttle, -1, 1)) //Wall detection
case -1:
if (RangeB() <= 10) {
//terminal.println("Wall Detected Stopping");
MBrake();
units = 0;
} else if (RangeB() <= 50) {
//terminal.println("Slowing down");
MDrive(0, -60, Steering);
break;
case 1:
if (RangeF() <= 10) {
MBrake();
units = 0;
} else if (RangeF() <= 50) {
//terminal.println("Slowing Down");
MDrive(0, 60, Steering);
break;
default:
break;
countR++;
countF++;
if (countF >= units) {
if (countR >= units) {
MBrake();
void MRUnit() {
switch (Trigger) {
case false:
break;
case true:
Serial.println("Starting Motor");
Blynk.syncVirtual(V10);
MUnit(RunitsF, Speed, Rsteer);
default:
break;
void MDrive(boolean Debug, int j, int k) {
switch (Debug) {
case 1:
Blynk.syncVirtual(V8, V9); //Debug remote drive //Very laggy
j = Y;
k = X;
default:
int A = 0, B = 0, C = 0, D = 0;
if (j == 0) {
//Forward Backwards
A = constrain(j, 0, 255);
C = constrain(j, 0, 255);
B = abs(constrain(j, -255, 0));
D = abs(constrain(j, -255, 0));
//Steering
A = A - (abs(constrain(k, -255, 0)) * constrain(A, 0, 1));
C = C - (abs(constrain(k, 0, 255)) * constrain(C, 0, 1));
B = B - (abs(constrain(k, -255, 0)) * constrain(B, 0, 1));
D = D - (abs(constrain(k, 0, 255)) * constrain(D, 0, 1));
analogWrite(motor1F, A);
analogWrite(motor1B, B);
analogWrite(motor2F, C);
analogWrite(motor2B, D);
break;
void HitCheck() {
if (pulseIn(2, LOW)) {
switch (StartStop) {
case true:
StartStop = false;
//terminal.println("Falsed");
break;
case false:
StartStop = true;
//terminal.println("Trued");
break;
} else if (pulseIn(4, LOW)) {
switch (BoxLoad) {
case true:
BoxLoad = false;
//terminal.println("Tone");
break;
case false:
BoxLoad = true;
//terminal.println("NoTone");
break;
int RangeB() {
long pulseDuration; //variable needed by the ultrasound sensor code
int Distance; // Ultrasound distance in cm
// this main code runs repeatedly:
// 1. Produce a 15us (micro-second) HIGH pulse in Trig to trigger the sensor...
digitalWrite(trigPinF, LOW);
delayMicroseconds(2);
digitalWrite(trigPinF, HIGH);
delayMicroseconds(5);
// 2. Use pulseIn() function to measure the duration of the HIGH pulse in Echo
// every 58 us is an obstacle distance of 1 cm
pulseDuration = pulseIn(echoPinF, HIGH);
Distance = pulseDuration / 58;
return Distance;
int RangeF() {
digitalWrite(trigPinB, LOW);
digitalWrite(trigPinB, HIGH);
pulseDuration = pulseIn(echoPinB, HIGH);
return Distance;
