Can some one give me the blynk export demo example code, I can not fine that in my examples
WhY do you mean by Blynk Export Demo Example?
What is it that you are trying to achieve, and what hardware are you wanting to run this code on?
I need to connect blynk API app to my ESP8266, my target is to make something “SonOff” Products
You still aren’t providing enough information for us to point you in the right direction.
Do you want to use the Blynk app to control a relay attached to a NodeMCU?
Are you using Blynk Legacy, or Blynk IoT ?
How much C++ programming experience do you have?
Thank you PereKnight,
So my target is to make an IoT control switch with NodeMCU, and I am expecting to give the hardware and application when we are giving it is hard to set up wifi SSD and password by using code, So, My target is to make something like this " https://youtu.be/RLKuIHaraKs " but I was not able to find this example code in my blynk examples.
You should use the Edgent ESP8266 example.
Thank you,
Mr. PereKnight and Mr. Dmitry
