Hello, I would like to share my method of using an ESP8266 (standalone) and three large sliders in the Blynk app to control the red, green, and blue components of a strip of APA102 Leds (also known as DotStars). I used the Arduino IDE to upload the code linked below:
Next I’d like to write a sketch to control parameters in the FastLed Library, but since FastLed doesn’t run on the ESP8266, I’ll need to set up the ESP as a WiFi shield connected to an Arduino. Cheers!
Video Here. P.S. I am not using logic level shifters to connect the ESP8266 to the strip of LEDs, but sometimes it is difficult to get the ESP to boot up and run the program after a power-off. I find that it helps when I disconnect the data pin from GPIO 15 when powering on. I’m curious to know if any other libraries for APA102 are compatible with the ESP. If you’re running APA102 LEDs directly from an ESP, what library are you using?
You know gpio15 needs to be low at boot, right? I had endless fun with the boot pins (0,2,15) and only used them why I know (can control) what their external startup states will be.
Ms. Linda: Do you sell on AliExpress or only Alibaba? IF you sell on AliExpress (for us small quantity buyers), what is the name of your store or through whom do you sell? I searched and could not find SFLeds.
