I have a problem with the connection of blynk with the arduino uno and connection with esp-01 S Series, It keeps on connecting and disconnecting the blynk. Im using 1.2.0 Blynk Library 9600 baud is working for me I already reconfigure my ESP - 01S
here’s the code
#define BLYNK_TEMPLATE_ID "****"
#define BLYNK_TEMPLATE_NAME "****"
#define BLYNK_AUTH_TOKEN "****"
#include <ESP8266_Lib.h>
char ssid[] = "WifiKo";
char pass[] = "******";
LiquidCrystal_I2C lcd(0x27, 16, 2);
#define MQ3_PIN A0 // MQ-3 Alcohol Sensor pin
#define BUTTON_PIN 12 // Push button connected to pin 12
#define LED_PIN 13 // Motor LED connected to pin 13
#define BRAKE_LIGHT_PIN 8 // Brake light LED connected to pin 8
#define BUZZER_PIN 9 // Buzzer connected to pin 9
#define ALCOHOL_THRESHOLD 300
#define ESP8266_BAUD 9600
bool ledState = false; // Keeps track of the LED state (on/off)
bool lastButtonState = HIGH; // Previous state of the button
bool buttonPressed = false; // Flag to detect button press
ESP8266 wifi(&EspSerial);
// Function to read alcohol level and send it to Blynk
void readAlcoholSensor() {
int alcoholValue = analogRead(MQ3_PIN);
// Print alcohol level to Serial Monitor
Serial.print("Alcohol Level: ");
Serial.println(alcoholValue);
// Display alcohol level on the LCD
lcd.setCursor(0, 0); // Set cursor to the first row
lcd.print("ALCOHOL: ");
lcd.print(alcoholValue);
lcd.print(" ");
// Send alcohol level to Blynk
Blynk.virtualWrite(V1, alcoholValue);
// Check alcohol level
if (alcoholValue > ALCOHOL_THRESHOLD) {
digitalWrite(LED_PIN, LOW); // Turn off the Motor LED (simulate motor OFF)
digitalWrite(BRAKE_LIGHT_PIN, HIGH); // Turn on the Brake Light LED
digitalWrite(BUZZER_PIN, HIGH); // Turn on the Buzzer
lcd.setCursor(0, 1);
lcd.print("ALC HIGH! STOP");
Serial.println("Motor Stopped: Alcohol Detected");
Blynk.logEvent("alcohol_high", "High alcohol level detected!");
delay(2000); // Pause for 2 seconds to display the message
digitalWrite(BUZZER_PIN, LOW); // Turn off the Buzzer
lcd.begin(); // Initialize the LCD
lcd.print("Alcohol Sensor");
delay(2000); // Display for 2 seconds
lcd.clear();
// Initialize button, LED, and buzzer pins
pinMode(BUTTON_PIN, INPUT_PULLUP); // Use internal pull-up resistor
pinMode(LED_PIN, OUTPUT); // Set Motor LED pin as output
pinMode(BRAKE_LIGHT_PIN, OUTPUT); // Set Brake Light LED pin as output
pinMode(BUZZER_PIN, OUTPUT); // Set Buzzer pin as output
lcd.print("Ready");
lcd.clear();
// Set ESP8266 baud rate
// Connect to Wi-Fi and Blynk
Blynk.begin(auth, wifi, ssid, pass, "blynk.cloud", 80);
// Setup a timer to read the alcohol sensor every 1 second
timer.setInterval(1000L, readAlcoholSensor);
Blynk.run(); // Run Blynk
timer.run(); // Run the timer
@CodEmbi Please edit your post, using the pencil icon at the bottom, and add triple backticks at the beginning and end of your code so that it displays correctly.
When you compile your sketch, what percentage of the available memory does the compiler say has been used?
What does your serial monitor show when the device connects and then disconnects? (Post the serial monitor text, not a screenshot, and don’t forget the triple backticks).
Have you tried a simpler sketch, without all of the additional hardware and its associated code?
Im using the 3.3v of arduino to power up the ESP-01.
Sketch Compile: Sketch uses 21042 bytes (65%) of program storage space. Maximum is 32256 bytes.
Global variables use 1243 bytes (60%) of dynamic memory, leaving 805 bytes for local variables. Maximum is 2048 bytes.
I have a previous code working but the moment I added the blynk.logEvent everything change the blynk going Online and Offline I thought the baud rate of ESP-01s was reset again then I tried to communicate with AT commands but still it was running on 9600 but the default baud rate after I bought this ESP-01s was 115200
What exactly does that mean?
Are you using your phone as a hotspot for the device?
It looks like your device can’t see the internet, despite being connected to WiFi.
If you’re using a home internet setup then rebooting your router would be the first thing to try.
yah Im using mobile hotspot, I have a update regarding to my problem this code is working but when I add blynk.logEvent the same problem will appear again the On and Off like that. I downgraded my Blynk library to 0.6
#define BLYNK_TEMPLATE_ID "TMPL6_dbV9R37"
#define BLYNK_TEMPLATE_NAME "VA"
#define BLYNK_AUTH_TOKEN "3wCHyfiL675hNB9VY2dnLOozXOZlJBgD"
char pass[] = "87654321";
lcd.begin(); // No need to specify the size when using LiquidCrystal_I2C
lcd.clear();
lcd.print("Ready");
lcd.clear();
// Read alcohol level from the MQ-3 sensor
lcd.print("ALCOHOL\:");
lcd.print(" ");
// If alcohol is detected above the threshold
// Alcohol level below threshold, check button state
if (digitalRead(BUTTON_PIN) == LOW && lastButtonState == HIGH) {
// Detect button press (change from HIGH to LOW)
delay(50); // Debounce delay
buttonPressed = true;
if (buttonPressed) {
// Toggle the LED state when button is pressed
ledState = !ledState;
digitalWrite(LED_PIN, ledState ? HIGH : LOW); // Update LED based on state
if (ledState) {
digitalWrite(BRAKE_LIGHT_PIN, LOW); // Turn off the Brake Light LED
lcd.print("Motor: ON ");
Serial.println("Motor Running");
Blynk.virtualWrite(V2, 255); // Send motor status to Virtual Pin 2
Blynk.virtualWrite(V3, 0); // Send motor status to Virtual Pin 3
lcd.print("Motor: OFF ");
Serial.println("Motor Stopped");
Blynk.virtualWrite(V2, 0); // Send motor status to Virtual Pin 2
Blynk.virtualWrite(V3, 255); // Send motor status to Virtual Pin 3
buttonPressed = false; // Reset button press state
lastButtonState = digitalRead(BUTTON_PIN); // Update the button state
delay(500); // Update every 500ms
You need to be running the latest version which is 1.3.2
Library version 0.6x is not compatible with Blynk IoT.
Your latest code is a massive step backwards. It has a cluttered void loop and delays, neither of which are compatible with Blynk.
I suspect that your issue is that you’re using your phone hotspot, as your earlier serial output indicated that there was no internet connection available for the device.
Thee are certainly issues with your Blynk.logEvent code logic, as it could easily result in you reaching your 24 hour limit of 100 events, but it won’t cause your device to fail to connect.
