I have loaded following sketch into my arduino Uno board.
I dont have ethernet of wifi shield so,I want to read my data via serial interface.
So,please help me out how to do in windows desktop so,that i can read sensor values in my blynk app
This sketch sends ads1115 current sensor data via HTTP POST request to thingspeak server.
It needs the following libraries to work (besides the esp8266 standard libraries supplied with the IDE):
- https://github.com/adafruit/Adafruit_ADS1X15
designed to run directly on esp8266-01 module, to where it can be uploaded using this marvelous piece of software:
2015 Tisham Dhar
licensed under GNU GPL
#include <FS.h> //this needs to be first, or it all crashes and burns..
#if PLATFORM_ID == 88
#include "application.h"
#else
#include <Wire.h>
#endif
//#define Serial SerialUSB
//#define Serial Serial1
#if defined(ARDUINO)
SYSTEM_MODE(MANUAL);//do not connect to cloud
#else
SYSTEM_MODE(AUTOMATIC);//connect to cloud
#endif
#include <Adafruit_ADS1015.h>
#include <Adafruit_NeoPixel.h>
#include <DNSServer.h> //Local DNS Server used for redirecting all requests to the configuration portal
#include <ESP8266WebServer.h> //Local WebServer used to serve the configuration portal
#include <WiFiManager.h> //https://github.com/tzapu/WiFiManager WiFi Configuration Magic
#include <ArduinoJson.h> //https://github.com/bblanchon/ArduinoJson
char auth[36] = "YOUR_BLYNK_TOKEN";
//flag for saving data
bool shouldSaveConfig = false;
//callback notifying us of the need to save config
void saveConfigCallback () {
Serial.println("Should save config");
shouldSaveConfig = true;
bool notifyFlag = false;
#define VIRTUAL_EN_PUSH V0
#define VIRTUAL_POWER V1
#define VIRTUAL_VOLTAGE V2
#define VIRTUAL_CURRENT V3
#define VIRTUAL_LCD V4
#define VIRTUAL_PF V5
WidgetLCD lcd(VIRTUAL_LCD);
bool pushEnabled = false;
// Hardware Definitions //
const int LED_PIN = 5;
const int RGB_PIN = 4;
Adafruit_NeoPixel rgb = Adafruit_NeoPixel(1, RGB_PIN, NEO_GRB + NEO_KHZ800);
void setLED(uint8_t red, uint8_t green, uint8_t blue);
#ifdef ESP8266
#include <pgmspace.h>
#else
#include <avr/pgmspace.h>
#endif
Adafruit_ADS1115 ads; /* Use this for the 16-bit version */
//Maximum value of ADS
#define ADC_COUNTS 32768
#define PHASECAL 1.7
#define VCAL 0.8
#define ICAL 0.04
double filteredI;
double lastFilteredV, filteredV; //Filtered_ is the raw analog value minus the DC offset
int sampleV; //sample_ holds the raw analog read value
int sampleI;
double offsetV; //Low-pass filter output
double offsetI; //Low-pass filter output
//Scaling for final calibration
double vmult = 1.0, imult = 1.0, phmult = 1.0;
double realPower,
apparentPower,
powerFactor,
Vrms,
Irms;
double phaseShiftedV; //Holds the calibrated phase shifted voltage.
int startV; //Instantaneous voltage at start of sample window.
double sqV, sumV, sqI, sumI, instP, sumP; //sq = squared, sum = Sum, inst = instantaneous
boolean lastVCross, checkVCross; //Used to measure number of times threshold is crossed.
double squareRoot(double fg)
double n = fg / 2.0;
double lstX = 0.0;
while (n != lstX)
lstX = n;
n = (n + fg / n) / 2.0;
return n;
void calcVI(unsigned int crossings, unsigned int timeout)
unsigned int crossCount = 0; //Used to measure number of times threshold is crossed.
unsigned int numberOfSamples = 0; //This is now incremented
// 1) Waits for the waveform to be close to 'zero' (mid-scale adc) part in sin curve.
boolean st = false; //an indicator to exit the while loop
unsigned long start = millis(); //millis()-start makes sure it doesnt get stuck in the loop if there is an error.
while(st==false) //the while loop...
startV = ads.readADC_Differential_2_3(); //using the voltage waveform
if ((startV < (ADC_COUNTS*0.6)) && (startV > (-ADC_COUNTS*0.6))) st=true; //check its within range
if ((millis()-start)>timeout) st = true;
// 2) Main measurement loop
start = millis();
while ((crossCount < crossings) && ((millis() - start) < timeout))
numberOfSamples++; //Count number of times looped.
lastFilteredV = filteredV; //Used for delay/phase compensation
// A) Read in raw voltage and current samples
sampleV = ads.readADC_Differential_0_1(); //Read in raw voltage signal
sampleI = ads.readADC_Differential_2_3(); //Read in raw current signal
// B) Apply digital low pass filters to extract the 2.5 V or 1.65 V dc offset,
// then subtract this - signal is now centred on 0 counts.
offsetV = offsetV + ((sampleV - offsetV) / 1024);
filteredV = sampleV - offsetV;
offsetI = offsetI + ((sampleI - offsetI) / 1024);
filteredI = sampleI - offsetI;
// C) Root-mean-square method voltage
sqV = filteredV * filteredV; //1) square voltage values
sumV += sqV; //2) sum
// D) Root-mean-square method current
sqI = filteredI * filteredI; //1) square current values
sumI += sqI; //2) sum
// E) Phase calibration
phaseShiftedV = lastFilteredV + PHASECAL * (filteredV - lastFilteredV);
// F) Instantaneous power calc
instP = phaseShiftedV * filteredI; //Instantaneous Power
sumP += instP; //Sum
// G) Find the number of times the voltage has crossed the initial voltage
// - every 2 crosses we will have sampled 1 wavelength
// - so this method allows us to sample an integer number of half wavelengths which increases accuracy
lastVCross = checkVCross;
if (sampleV > startV) checkVCross = true;
else checkVCross = false;
if (numberOfSamples == 1) lastVCross = checkVCross;
if (lastVCross != checkVCross) crossCount++;
// 3) Post loop calculations
//Calculation of the root of the mean of the voltage and current squared (rms)
//Calibration coefficients applied.
float multiplier = 0.125F; /* ADS1115 @ +/- 4.096V gain (16-bit results) */
double V_RATIO = VCAL * multiplier;
Vrms = V_RATIO * squareRoot(sumV / numberOfSamples);
double I_RATIO = ICAL * multiplier;
Irms = I_RATIO * squareRoot(sumI / numberOfSamples);
//Calculation power values
realPower = V_RATIO * I_RATIO * sumP / numberOfSamples;
apparentPower = Vrms * Irms;
powerFactor = realPower / apparentPower;
//Reset accumulators
sumV = 0;
sumI = 0;
sumP = 0;
void readBlynkConfig()
//clean FS, for testing
//SPIFFS.format();
//read configuration from FS json
//Serial.println("mounting FS...");
if (SPIFFS.begin()) {
//Serial.println("mounted file system");
if (SPIFFS.exists("/config.json")) {
//file exists, reading and loading
//Serial.println("reading config file");
File configFile = SPIFFS.open("/config.json", "r");
if (configFile) {
//Serial.println("opened config file");
size_t size = configFile.size();
// Allocate a buffer to store contents of the file.
std::unique_ptr<char[]> buf(new char[size]);
configFile.readBytes(buf.get(), size);
DynamicJsonBuffer jsonBuffer;
JsonObject& json = jsonBuffer.parseObject(buf.get());
json.printTo(Serial);
if (json.success()) {
//Serial.println("\nparsed json");
strcpy(auth, json["auth"]);
//Serial.println("failed to load json config");
//Serial.println("failed to mount FS");
//end read
void saveBlynkConfig()
//save the custom parameters to FS
if (shouldSaveConfig) {
//Serial.println("saving config");
JsonObject& json = jsonBuffer.createObject();
json["auth"] = auth;
File configFile = SPIFFS.open("/config.json", "w");
if (!configFile) {
//Serial.println("failed to open config file for writing");
json.printTo(configFile);
configFile.close();
//end save
void readMultConfig()
//SPIFFS.format();
if (SPIFFS.exists("/mult.json")) {
File configFile = SPIFFS.open("/mult.json", "r");
if (configFile) {
vmult = json["vmult"];
imult = json["imult"];
phmult = json["phmult"];
//end read
void saveMultConfig()
//save the multiplier parameters to FS
json["vmult"] = vmult;
json["imult"] = imult;
json["phmult"] = phmult;
File configFile = SPIFFS.open("/mult.json", "w");
if (!configFile) {
configFile.close();
//end save
pinMode(LED_PIN, OUTPUT);
digitalWrite(LED_PIN, LOW); // Turn off blue LED
rgb.begin(); // Set up WS2812
setLED(0, 0, 32); // LED blue
ads.setGain(GAIN_ONE); // 1x gain +/- 4.096V 1 bit = 0.125mV
ads.begin();
Wire.begin();
//Read previous config
readBlynkConfig();
readMultConfig();
// The extra parameters to be configured (can be either global or just in the setup)
// After connecting, parameter.getValue() will get you the configured value
// id/name placeholder/prompt default length
WiFiManagerParameter custom_blynk_token("blynk", "blynk token", auth, 33);
//Use wifi manager to get config
WiFiManager wifiManager;
wifiManager.setDebugOutput(false);
//set config save notify callback
wifiManager.setSaveConfigCallback(saveConfigCallback);
//add all your parameters here
wifiManager.addParameter(&custom_blynk_token);
//first parameter is name of access point, second is the password
wifiManager.autoConnect("Blynkwhatnick", "EnergyMonitor");
Serial.println("connected...yeey :)");
//read updated parameters
strcpy(auth, custom_blynk_token.getValue());
saveBlynkConfig();
// Initialize Blynk, and wait for a connection before doing anything else
Serial.println("Connecting to Blynk Server");
Blynk.config(auth);
while (!Blynk.connected())
Serial.println("Blynk connected! Energy monitor starting.");
setLED(0, 32, 0); // LED green
// init done
int lastTick = 0;
if ((millis() - lastTick > 10000)) { //60000 - 1 minute
measureVI();
lastTick = millis();
Serial.print("Vrms:");
Serial.println(Vrms * vmult);
Serial.print("Irms:");
Serial.println(Irms * imult);
Serial.print("Power:");
Serial.println(realPower * vmult * imult);
Serial.print("p.f.:");
Serial.println(powerFactor * phmult);
yield();
bool firstConnect = true;
BLYNK_CONNECTED()
if (firstConnect) // When we first connect to Blynk
// Two options here. Either sync values from phone to Blynk Board:
//Blynk.syncAll(); // Uncomment to enable.
// Or set phone variables to default values of the globals:
Blynk.virtualWrite(VIRTUAL_POWER, realPower * vmult * imult);
Blynk.virtualWrite(VIRTUAL_CURRENT, Irms * imult);
Blynk.virtualWrite(VIRTUAL_VOLTAGE, Vrms * vmult);
Blynk.virtualWrite(VIRTUAL_PF, powerFactor * phmult);
// Print a splash screen:
lcd.clear();
lcd.print(0, 0, "Energy Monitor ");
lcd.print(0, 1, " Ready ");
void measureVI()
calcVI(20, 2000);
// Write the values to Blynk:
BLYNK_WRITE(V6) //Button Widget is writing to pin V6
int pinData = param.asInt();
vmult = pinData / 100.0f;
Serial.print("V Mult: ");
Serial.println(vmult);
saveMultConfig();
BLYNK_WRITE(V7) //Button Widget is writing to pin V7
imult = pinData / 100.0f;
Serial.print("I Mult: ");
Serial.println(imult);
saveMultConfig();
BLYNK_WRITE(V8) //Button Widget is writing to pin V8
phmult = pinData / 100.0f;
Serial.print("Phase Mult: ");
Serial.println(phmult);
saveMultConfig();
rgb.setPixelColor(0, rgb.Color(red, green, blue));
rgb.show();
