Dear Sirs,
I have tried all possible tricks but I cannot sent Blynk.email to a recipient other than the registered email at the Blynk.email widget. For me, even the simple blynk example doesn’t work. WHY? What is the catch?
http://twitter.com/blynk_app
Simple e-mail example
App project setup:
E-mail Widget
Connect a button to digital pin 2 and GND
Pressing this button will send an e-mail
WARNING: You are limited to send ONLY ONE E-MAIL PER 15 SECONDS!
/* Set this to a bigger number, to enable sending longer messages */
//#define BLYNK_MAX_SENDBYTES 128
char auth[] = "xxxxx";
char ssid[] = "testSSID";
char pass[] = "12345678";
void emailOnButtonPress()
// *** WARNING: You are limited to send ONLY ONE E-MAIL PER 15 SECONDS! ***
// Let's send an e-mail when you press the button
// connected to digital pin 2 on your Arduino
int isButtonPressed = !digitalRead(2); // Invert state, since button is "Active LOW"
if (isButtonPressed) // You can write any condition to trigger e-mail sending
Serial.println("Button is pressed."); // This can be seen in the Serial Monitor
Blynk.email("xxxx@mydomain.com", "Subject: Button Logger", "You just pushed the button...");
// Or, if you want to use the email specified in the App (like for App Export):
//Blynk.email("Subject: Button Logger", "You just pushed the button...");
// Send e-mail when your hardware gets connected to Blynk Server
// Just put the recepient's "e-mail address", "Subject" and the "message body"
Blynk.email("xxxx@mydomain.com", "Subject", "My Blynk project is online.");
// Setting the button
pinMode(2, INPUT_PULLUP);
// Attach pin 2 interrupt to our handler
attachInterrupt(digitalPinToInterrupt(2), emailOnButtonPress, CHANGE);
(Yes I am a lill’ stinker at times
