Hey there,
so i got the problem, that after like 5-10 minutes my ESP loses connection to wifi opening up it´s AP and not reconnecting again. The Router is right next to the ESP, so that should not be a Problem. The Router is a 4G LTE wifi router. Maybe i could first try to set a static IP but i have no idea of how to do that with Blynk Edgent. Any other ideas of what could possibly cause that?
* Blynk Parameter
#define BLYNK_TEMPLATE_ID "xxxxxxxxx"
#define BLYNK_DEVICE_NAME "xxxxxxxxxx"
#define BLYNK_FIRMWARE_VERSION "1.0.4"
#define USE_SHELLY1
* Include Section
#include "Arduino.h"
#include "BlynkEdgent.h"
#include <OneWire.h>
#include <Wire.h>
#include <string>
* Sensor Bus Parameter
#define ONE_WIRE_BUS 0
// SensorBus Init
DeviceAddress sensor1 = {0x28, 0x7D, 0xE3, 0x3, 0xD, 0x0, 0x0, 0xC0};
DeviceAddress sensor2 = {0x28, 0xFF, 0x64, 0x1E, 0x23, 0xAA, 0xA5, 0x82};
DeviceAddress sensor3 = {0x28, 0x44, 0x89, 0x9A, 0x12, 0x21, 0x1, 0x2B};
DeviceAddress sensor4 = {0x28, 0x87, 0xA, 0x14, 0x12, 0x21, 0x1, 0xA4};
DeviceAddress sensor5 = {0x28, 0xC7, 0x79, 0x5B, 0xB5, 0x21, 0x6, 0x87};
DeviceAddress sensor6 = {0x28, 0x64, 0x4C, 0x14, 0x12, 0x21, 0x1, 0xA1};
DeviceAddress sensor7 = {0x28, 0x37, 0xCE, 0x6E, 0xB5, 0x21, 0x6, 0x22};
DeviceAddress sensor8 = {0x28, 0xC2, 0x41, 0x15, 0x12, 0x21, 0x1, 0x2C};
DeviceAddress sensor9 = {0x28, 0x43, 0x50, 0xFC, 0x17, 0x20, 0x6, 0xE8};
DeviceAddress sensor10 = {0x28, 0xFF, 0x64, 0x1E, 0x23, 0x86, 0x7, 0x1D};
// Sensor Variablen
BlynkTimer SensorTimer;
byte resolution = 9; // Sensor Auflösung
float TempSensor1;
float TempSensor2;
float TempSensor3;
float TempSensor4;
float TempSensor5;
float TempSensor6;
float TempSensor7;
float TempSensor8;
float TempSensor9;
float TempSensor10;
* BUS Abfrage
void readBusandSend()
sensors.requestTemperatures();
TempSensor1 = sensors.getTempC(sensor1) - 8,85 ;
TempSensor2 = sensors.getTempC(sensor2) - 3;
TempSensor3 = sensors.getTempC(sensor3);
TempSensor4 = sensors.getTempC(sensor4);
TempSensor5 = sensors.getTempC(sensor5) - 3;
TempSensor6 = sensors.getTempC(sensor6) - 8;
TempSensor7 = sensors.getTempC(sensor7) - 8,5;
TempSensor8 = sensors.getTempC(sensor8) - 8,1;
TempSensor9 = sensors.getTempC(sensor9) - 8,2;
TempSensor10 = sensors.getTempC(sensor10);
Blynk.virtualWrite(1, TempSensor1);
Blynk.virtualWrite(2, TempSensor2);
Blynk.virtualWrite(3, TempSensor3);
Blynk.virtualWrite(4, TempSensor4);
Blynk.virtualWrite(5, TempSensor5);
Blynk.virtualWrite(6, TempSensor6);
Blynk.virtualWrite(7, TempSensor7);
Blynk.virtualWrite(8, TempSensor8);
Blynk.virtualWrite(9, TempSensor9);
Blynk.virtualWrite(10, TempSensor10);
// Sensor init
sensors.begin();
sensors.setResolution(sensor1, resolution);
sensors.setResolution(sensor2, resolution);
sensors.setResolution(sensor3, resolution);
sensors.setResolution(sensor4, resolution);
sensors.setResolution(sensor5, resolution);
sensors.setResolution(sensor6, resolution);
sensors.setResolution(sensor7, resolution);
sensors.setResolution(sensor8, resolution);
sensors.setResolution(sensor9, resolution);
sensors.setResolution(sensor10, resolution);
sensors.setWaitForConversion(false);
// Blynk init
BlynkEdgent.begin();
// 1. Bus-Abfrage
readBusandSend();
// Timer init
SensorTimer.setInterval(10000L, readBusandSend);
* Main Loop
// Start Blynk
BlynkEdgent.run();
SensorTimer.run();
Thanks in advance!
