Hey, i’m having trouble with one of my projects. I was trying to build a home automation system which remembers the previous state in case of a power loss, but after uploading the code I’m not able to connect my Node MCU esp-12E with the blynk app.
#include <EEPROM.h>
#define BLYNK_TEMPLATE_ID "TMPLBzK5MDXo"
#define BLYNK_DEVICE_NAME "HomeUTOMATION"
//#define BLYNK_DEBUG
#define APP_DEBUG
// Uncomment your board, or configure a custom board in Settings.h
//#define USE_SPARKFUN_BLYNK_BOARD
#define USE_NODE_MCU_BOARD
//#define USE_WITTY_CLOUD_BOARD
//#define USE_WEMOS_D1_MINI
#include "BlynkEdgent.h"
int fan_Speed1 = HIGH;
int fan_Speed2 = HIGH;
int fan_Speed3 = HIGH;
int fan_Speed4 = HIGH;
int Speed1 = 14;
int Speed2 = 12;
int Speed3 = 4;
int Speed4 = 5;
int Speed1add = 1;
int Speed2add = 2;
int Speed3add = 3;
int Speed4add = 4;
BLYNK_WRITE(V12)
fan_Speed1 = param.asInt(); // assigning incoming value from pin V1 to a variable
digitalWrite(Speed1, fan_Speed1);
EEPROM.write(Speed1add, fan_Speed1);
EEPROM.commit();
BLYNK_WRITE(V13)
fan_Speed2 = param.asInt(); // assigning incoming value from pin V1 to a variable
digitalWrite(Speed2, fan_Speed2);
EEPROM.write(Speed2add, fan_Speed2);
EEPROM.commit();
BLYNK_WRITE(V14)
fan_Speed3 = param.asInt(); // assigning incoming value from pin V1 to a variable
digitalWrite(Speed3, fan_Speed3);
EEPROM.write(Speed3add, fan_Speed3);
EEPROM.commit();
BLYNK_WRITE(V15)
fan_Speed4 = param.asInt(); // assigning incoming value from pin V1 to a variable
digitalWrite(Speed4, fan_Speed4);
EEPROM.write(Speed4add, fan_Speed4);
EEPROM.commit();
EEPROM.begin(512);
if (EEPROM.read(Speed1add) == 255)
fan_Speed1 = HIGH; //default turn off value for relay
fan_Speed1 = EEPROM.read(Speed1add);
if (EEPROM.read(Speed2add) == 255)
fan_Speed2 = HIGH;//default turn off value for relay
fan_Speed2 = EEPROM.read(Speed2add);
if (EEPROM.read(Speed3add) == 255)
fan_Speed3 = HIGH;//default turn off value for relay
fan_Speed3 = EEPROM.read(Speed3add);
if (EEPROM.read(Speed4add) == 255)
fan_Speed4 = HIGH;//default turn off value for relay
fan_Speed4 = EEPROM.read(Speed4add);
pinMode(Speed1, OUTPUT);
pinMode(Speed2, OUTPUT);
pinMode(Speed3, OUTPUT);
pinMode(Speed4, OUTPUT);
//TURN OFF all Relays on Start
Serial.println("Begin");
delay(100);
BlynkEdgent.begin();
BlynkEdgent.run();
After Uploading the output is this
Begin
[621] Using default config.
[621]
___ __ __
/ _ )/ /_ _____ / /__
/ _ / / // / _ \/ '_/
/____/_/\_, /_[621] Hold the button for 10 seconds to reset configuration...
//_/[627] Hold the button for 10 seconds to reset configuration...
_/\_\[633] Hold the button for 10 seconds to reset configuration...
[639] Hold the button for 10 seconds to reset configuration...
/[645] Hold the button for 10 seconds to reset configuration...
___/ [651] Hold the button for 10 seconds to reset configuration...
v[656] Hold the button for 10 seconds to reset configuration...
1.1.0 on [663] Hold the button for 10 seconds to reset configuration...
NodeM[669] Hold the button for 10 seconds to reset configuration...
CU[675] Hold the button for 10 seconds to reset configuration...
[680] Hold the button for 10 seconds to reset configuration...
[686] Hold the button for 10 seconds to reset configuration...
#St[692] Hold the button for 10 seconds to reset configuration...
andWithUkrai[698] Hold the button for 10 seconds to reset configuration...
[704] Hold the button for 10 seconds to reset configuration...
ne[710] Hold the button for 10 seconds to reset configuration...
[715] Hold the button for 10 seconds to reset configuration...
[721] Hold the button for 10 seconds to reset configuration...
[727] Hold the button for 10 seconds to reset configuration...
[732] Hold the button for 10 seconds to reset configuration...
h[738] Hold the button for 10 seconds to reset configuration...
ttps[744] Hold the button for 10 seconds to reset configuration...
:[749] Hold the button for 10 seconds to reset configuration...
//bit.ly/[756] Hold the button for 10 seconds to reset configuration...
swua
[762] Hold the button for 10 seconds to reset configuration...
[[768] Hold the button for 10 seconds to reset configuration...
768] [774] Hold the button for 10 seconds to reset configuration...
-----[780] Hold the button for 10 seconds to reset configuration...
--------------[787] Hold the button for 10 seconds to reset configuration...
[792] Hold the button for 10 seconds to reset configuration...
--[798] Hold the button for 10 seconds to reset configuration...
---[804] Hold the button for 10 seconds to reset configuration...
[81[810] Hold the button for 10 seconds to reset configuration...
0[815] Hold the button for 10 seconds to reset configuration...
] Pro[821] Hold the button for 10 seconds to reset configuration...
duct: Ho[828] Hold the button for 10 seconds to reset configuration...
meUTO[834] Hold the button for 10 seconds to reset configuration...
MATION[840] Hold the button for 10 seconds to reset configuration...
[[846] Hold the button for 10 seconds to reset configuration...
846] Fi[852] Hold the button for 10 seconds to reset configuration...
rmwar[858] Hold the button for 10 seconds to reset configuration...
e:[864] Hold the button for 10 seconds to reset configuration...
0.1.0 [870] Hold the button for 10 seconds to reset configuration...
(build[876] Hold the button for 10 seconds to reset configuration...
Au[882] Hold the button for 10 seconds to reset configuration...
g 2[887] Hold the button for 10 seconds to reset configuration...
2 [893] Hold the button for 10 seconds to reset configuration...
2[899] Hold the button for 10 seconds to reset configuration...
02[904] Hold the button for 10 seconds to reset configuration...
2 18:15:18)
[[911] Hold the button for 10 seconds to reset configuration...
9[917] Hold the button for 10 seconds to reset configuration...
1[923] Hold the button for 10 seconds to reset configuration...
1] Device[929] Hold the button for 10 seconds to reset configuration...
: N[935] Hold the button for 10 seconds to reset configuration...
ode[941] Hold the button for 10 seconds to reset configuration...
MCU @ 80MHz
[9[948] Hold the button for 10 seconds to reset configuration...
47] [954] Hold the button for 10 seconds to reset configuration...
MA[959] Hold the button for 10 seconds to reset configuration...
C:[965] Hold the button for 10 seconds to reset configuration...
[971] Hold the button for 10 seconds to reset configuration...
84:C[977] Hold the button for 10 seconds to reset configuration...
C:A8:[983] Hold the button for 10 seconds to reset configuration...
86:57[989] Hold the button for 10 seconds to reset configuration...
:[994] Hold the button for 10 seconds to reset configuration...
42
[1[1001] Hold the button for 10 seconds to reset configuration...
000][1007] Hold the button for 10 seconds to reset configuration...
Exception (0):
epc1=0x4020101c epc2=0x00000000 epc3=0x00000000 excvaddr=0x00000000 depc=0x00000000
>>>stack>>>
ctx: cont
sp: 3ffffbf0 end: 3fffffc0 offset: 01a0
3ffffd90: 4010040a 00000000 00000000 40100490
3ffffda0: c0037030 00ff0000 ff000000 4100205d
3ffffdb0: 00000000 3fff1c58 00000000 00000022
3ffffdc0: 3fffc200 401003d0 3fffc258 4000050c
3ffffdd0: 400046ea 00000030 0000001d ffffffff
3ffffde0: 401048a3 00000000 00000000 00000001
3ffffdf0: 04000001 04000001 3feffe00 00000100
3ffffe00: 60000200 00000001 fffffffe 3fff0b58
3ffffe10: 3fff0b38 3ffe8a9d 3fffff00 00000030
3ffffe20: 3ffffed0 7fffffff 7ffffffd 3fff0b58
3ffffe30: 00000031 0000000a 3fff0b58 4020e17c
3ffffe40: 3ffffec0 4020f48c 3ffffebf 4020e531
3ffffe50: 3ffffe8c feefeffe feefeffe 0000000a
3ffffe60: 3ffe8b35 00000020 3ffffe8b 4020e837
3ffffe70: 00000000 4bc6a7f0 da9fbe76 00000000
3ffffe80: 3ffe866e 00000000 3ffe866d 402119f2
3ffffe90: 00000000 3fff0b38 40100294 3fffff00
3ffffea0: 3ffe8a9d 3fff0b38 3fff0b58 3fffff00
3ffffeb0: 3fffff0c 0000000a 3fffff00 4020f50e
3ffffec0: 3ffe866c 3fff0b38 3fffff00 4020f56c
3ffffed0: 4010579e 4010576a 3fffff00 4020f708
3ffffee0: 4020ddf8 0016405e 3fff0b58 4020f73c
3ffffef0: 3ffe8a9a 3fff0b38 3fff0b58 402029bd
3fffff00: 73616c46 20203a68 00002020 73616c46
3fffff10: 20203a68 00002020 00000000 00000000
3fffff20: ff002020 3fff0b58 3fff0669 4020194c
3fffff30: 40203e18 3fff0b58 3ffe84ec 3ffe8500
3fffff40: 3ffe84fc 3fff0b58 3ffe84ec 4020400c
3fffff50: feefeffe feefeffe feefeffe feefeffe
3fffff60: feefeffe feefeffe feefeffe feefeffe
3fffff70: feefeffe feefeffe feefeffe feefeffe
3fffff80: feefeffe feefeffe feefeffe feefeffe
3fffff90: feefeffe feefeffe feefeffe 3fff0c88
3fffffa0: 3fffdad0 00000000 3fff0c58 40210890
3fffffb0: feefeffe feefeffe 3ffe8580 40100885
<<<stack<<<
ets Jan 8 2013,rst cause:2, boot mode:(3,6)
load 0x4010f000, len 1384, room 16
tail 8
chksum 0x2d
csum 0x2d
v8b899c12
~ld
