Hey all!
Is it posible to run a blynk on openwrt? for example to blYnk some leds on my router?)
Not in the sense you want it I think. Maybe if it supports python though? Could be worth trying, but I think it’s gonna give you hard times
Yes it is possible, but we have currently no easy installation package…
maybe you have any tutorial?
Again, not yet.
- If you have node.js on your router - it will be very easy to run our JS library.
- Python/Lua could also work, but may require more work.
- At last, C++ library is available, but you will have to cross-compile it manually (may be complex, depends on your skills).
Every option is doable but different complexity, which one would you prefer?
can you please send me the C++ library?
Hey.
This is just linux folder inside of regular Arduino library: https://github.com/blynkkk/blynk-library
There’s a build script for linux/raspberry pi
