hi guys,
this is not a project made with blynk per se, but i did not know where to post it.
always wanted a desktop blynk app and now i found a solution, thought it might help someone else: nox app player
i am not affiliated with them, worked for me on os x without any issues. there s some cpu usage that i d prefer was smaller, but beggars can’t be choosers, right?
Yes, these Android Emulators can sure come in handy!!
I used Droid4X for awhile, even though is seems like a discontinued program. But then had to switch to an AMD processor and realised Droid4x only worked well on Intel.
I prefer BlueStacks. It works really well, the only thing you cannot do (on Mac anyway) is run VirtualBox and BlueStacks together because BlueStacks also uses virtualbox and it messes up your installation, so I’m running VMware for virtualization.
Old Foscam FI8910 P&T I would like to figure out how to control the P&T via network commands, and eventually Blynk… but that is a bit beyond my focus level at the time. Right now, if i want to move it around I use my Security DVR program.
Dear @Gunner ,
thanks a lot for your nice finding regarding the Android Emulation on PC !
I installed and it is running fine but there is a problem with the “fonts” especially at terminal widget. Did you see this problem at your installation(s)? Is there any workaround regarding the font size etc aesthetics ???
There is a notable difference in the amount of text per line and lines per terminal screen size and so on, but that is also the same between my main phone and tablet, not to mention any other device I try Blynk on… I think that is primarily driven by the devices resolution and ppi (pixel density), not by Blynk.
For example, this is the same project on my phone and on my tablet… subtle differences in font sizes, LED & slider graphics, even the keyboard emoticon images… ahh the joys of Android standards
You gave me a perfect advice regarding the resolution and PPI. ( dpi )
I put my Android phone numbers ( 1920 X 1080 @ 480 dpi ) and now everything appeared as it should !!! Thanks friend.
ah yes a professional way, well i am sure at some point you will want that to work and you will find how to do it.
Im going a bit more amateur style with these guys:
Hi I am having an issue with getting Nox to work with blynk, have you had any issues? Nox works fine with my other apk’s. Maybe there is a thread specifically for emulators. See image
@daveblynk This is an OLD topic. If you have current issues it is best to create a new topic… however, This is NOT really a Blynk issue anyhow.
I use NOX every day… works just fine with Blynk. Both Cloud and Local Server.
There was some issue with Local Server, wherein the App would slowdown and lockup, but that was related to any older version of Android, not just NOX… and regardless, it has cleared up between last App and Server update
