Blynk Create Your Own App Preview Problem
I am using a DHT11 Sensor and a ESP8266-01 WiFi module. My hardware works perfectly fine. My code does work perfectly fine. My only problem is with creating my own app option. I have created the app using the example esp8266 export code(and influenced by MyPlant App’s example code). I’ve use a previously working face for the app. But when I integrated the working code with the app example code, the data didn’t displayed in the App Preview… The data, however, displays on the serial monitor as intended and without any problems…
Phone OS: Android Oreo 8.0
Latest Blynk and Arduino IDE.
#define USE_CUSTOM_BOARD          // For all other ESP8266-based boards -
                                    // see "Custom board configuration" in Settings.h
#define APP_DEBUG        // Comment this out to disable debug prints
#include "BlynkProvisioning.h"
#include <SimpleDHT.h>
const char* host = "api.thingspeak.com";
const char* writeAPIKey = "REMOVED FOR SECURITY";
SimpleDHT11 dht11;
int pinDHT11 =  2;
  delay(5000);
  BlynkProvisioning.begin();
  BlynkProvisioning.run();
  byte temperature = 0;
  byte humidity = 0;
  int err = SimpleDHTErrSuccess;
 if ((err = dht11.read(pinDHT11, &temperature, &humidity, NULL)) != SimpleDHTErrSuccess) {
    Serial.print("No reading , err="); Serial.println(err);
    return;
  Serial.print("Readings: ");
  Serial.print((int)temperature); Serial.print(" Celcius, ");
  Serial.print((int)humidity); Serial.println(" %");
  Blynk.virtualWrite(V5, humidity);
  Blynk.virtualWrite(V6, temperature);
  WiFiClient client;
  const int httpPort = 80;
  if (!client.connect(host, httpPort)) {
    return;
  String url = "/update?key=";
  url+=writeAPIKey;
  url+="&field1=";
  url+=String(temperature);
  url+="&field2=";
  url+=String(humidity);
  url+="\r\n";
  client.print(String("GET ") + url + " HTTP/1.1\r\n" +
               "Host: " + host + "\r\n" +
               "Connection: close\r\n\r\n");
delay(700);
This is an Urgent problem. Please advise ASAP…
I think you need to read over the DOCS and look over a few of the examples on the Sketch Builder, ASAP. You have way too much stuff in your loop().
I don’t think thats a problem. The code works fine while I apply it to my project and not to the app version.
I DO think that is the problem. If you would have read through the DOCS you will see that what you are doing (reading temp from a DHT11) needs to be done with a timer in order to work well with BLYNK.
BLYNK 101 - No delay, and minimal code in loop()
Take a look at this example.
BLYNK DHT11
Alright I’ll give it a shot. But what about the thingspeak code at the end of the loop? What should I do with it? Another timer or just leave it there?
If you remove the delays, then leaving it will probably cause a flooding of thingspeak’s server. So a timer is a must have. But you probably don’t need “another one”. Just use one created.
You can use another timer, or the webhook widget.
Or, as @marvin7 stated you could put it in the same timer as the DHT11. If you go this route, make sure your interval is long enough that it doesn’t flood thingspeak.
I still have a question. This code works without the integration of Blynk Inject or other Create Your Own App code template… But when it comes to creating an App it doesn’t work… Is there an another cause to this other than the problem with loop?
Yes, it will work without BLYNK, and will most likely show correct results in the serial monitor (and possibly the app for short periods of time). What you will most likely see is that the connection to the app is constantly disconnecting and reconnecting. There are some inner workings of the BLYNK libraries and such that require the use of non-blocking functions, and a continuous “hand-shake” confirmation that it is still connected. This is why the loop() needs to be as short as possible, and why you cannot use delays.
Hope this clarifies it a bit. Maybe someone else might provide a better explanation.
Alright… I have one more question: how to add more than 1 devices to “Create Your Own App” feature. I am only able to add one currently.
I have not used the “Create Your Own App” feature. I only use the basic projects. From the little I have played around with it, it seems like the devices must be added before you create the app preview (i.e. while it is still a project).
Alright Update:
still seeing my screen like this despite the improvements to my void loop()
the data doesn’t somehow connect with “Create your own app” preview…
Post you new code
const char* writeAPIKey = "S4OY6V3OOEMCBYLG";
SimpleDHT11 dht11;
int pinDHT11 =  2;
void Temp(){
  byte humidity = 0;
    return;
  WiFiClient client;
    return;
  url+=writeAPIKey;
  url+="&field1=";
  url+="&field2=";
  url+="\r\n";
delay(700);
  delay(5000);
  Temp();
I can see the output on both serial monitor and this screen of the app:
Placing Temp() in your loop() is almost the same thing as having all the code in the loop(). Additionally, with those delays you are going to have disconnection issues. You need to use timers. First remove all delay() from Temp()
Then, Add this up top near your variable declarations.
Put this in your setup()
timer.setInterval(2000L, Temp);
Remove Temp() from the loop(), and add this to the loop()
As for the app preview part, I haven’t a clue. I just leave them as projects, as I have no desire to publish.
my only concern was with the app preview though… It doesn’t seem to function properly…
I suspect it is just that, a preview… not necessarily fully usable as a functioning App?
