Help please! I am making a logger system in blynk using arduino uno and gsm sim800 module for my project. When i used the blynk(legacy) app, it connects but the data wont show on my phone so i tried the new blynk console on my computer. now, it keeps saying invalid auth token. I tried deleting my device and making a new one to renew the auth token multiple times, even input in manually, its still says invalid auth token. What could be the problem?
Here’s my code I copied from the example sketch and just added codes to fit my template.
#define BLYNK_TEMPLATE_ID “TMPL7ZNT1E2z”
#define BLYNK_DEVICE_NAME “Wind Speed Logger”
#define BLYNK_AUTH_TOKEN “RL0r3a22184lkiYyKXqQPoMkb2o-Kcjc”
#define TINY_GSM_MODEM_SIM800
// Default heartbeat interval for GSM is 60
// If you want override this value, uncomment and set this option:
#define BLYNK_HEARTBEAT 250
#include <TinyGsmClient.h>
#include <BlynkSimpleSIM800.h>
// Your GPRS credentials
// Leave empty, if missing user or pass
char apn[] = “internet”;
char user[] = “”;
char pass[] = “”;
// Hardware Serial on Mega, Leonardo, Micro
//#define SerialAT Serial1
// or Software Serial on Uno, Nano
SoftwareSerial SerialAT(2, 3); // RX, TX
TinyGsm modem(SerialAT);
//Computations
const int windSensorPin = A1;
float voltageConversionConstant = 0.004882814;
//Anemometer parameters
float vol_min = 0.4;
float vol_max = 2.0;
float wind_min = 0;
float wind_max = 32;
//Average
const int num_readings = 16;
int readings[num_readings];
int readIndex = 0;
long total_wind = 0;
//Max Wind speed
double x = 0;
double y = 0;
float mapfloat(float x, float vol_min, float vol_max, float wind_min, float wind_max)
return (x - vol_min) * (wind_max - wind_min) / (vol_max - vol_min) + wind_min;
void sendSensor()
//Read the analog value from the anemometer
float sensorValue = analogRead(windSensorPin);
//Convert the analog value to actual voltage
float sensorVoltage = sensorValue * voltageConversionConstant;
//Current Wind Speed Computations
float current_windspeed_metric = mapfloat(sensorVoltage, 0.4, 2.0, 0, 32);
float current_windspeed_mph = current_windspeed_metric * 2.232694;
if (sensorVoltage <= vol_min) { //Eliminate the negative output values
current_windspeed_metric = 0;
current_windspeed_mph = 0;
Serial.println(“Current Wind = “);
Serial.print(current_windspeed_metric);
Serial.print(” m/s or “);
Serial.print(current_windspeed_mph);
Serial.print(” mph”);
//Average Wind Speed
float average_windspeed_metric;
float average_windspeed_mph;
total_wind = total_wind - readings[readIndex];
readings[readIndex] = current_windspeed_metric;
total_wind = total_wind + readings[readIndex];
readIndex = readIndex + 1;
if (readIndex >= num_readings)
readIndex = 0;
average_windspeed_metric = ((total_wind / num_readings) * 1.05);
average_windspeed_mph = average_windspeed_metric * 2.232694;
if (average_windspeed_metric <= 0) {
average_windspeed_metric = 0;
average_windspeed_mph = 0;
Serial.println(“Average Wind = “);
Serial.print(average_windspeed_metric);
Serial.print(average_windspeed_mph);
// Max Wind Speed
float max_windspeed_metric;
float max_windspeed_mph = max_windspeed_metric * 2.232694;
x = readings[readIndex];
if ( x >= max_windspeed_metric) {
max_windspeed_metric = x;
max_windspeed_metric = max_windspeed_metric;
Serial.println(“Max Wind = “);
Serial.print(max_windspeed_metric);
Serial.print(max_windspeed_mph);
// delay in between reads for stability
// Please don’t send more that 10 values per second.
Blynk.virtualWrite(V1, current_windspeed_metric);
Blynk.virtualWrite(V2, current_windspeed_mph);
Blynk.virtualWrite(V3, average_windspeed_metric);
Blynk.virtualWrite(V4, average_windspeed_mph);
Blynk.virtualWrite(V5, max_windspeed_metric);
Blynk.virtualWrite(V6, max_windspeed_mph);
Serial.begin(19200);
for (int thisReading = 0; thisReading < num_readings; thisReading++) {
readings[thisReading] = 0;
// Set GSM module baud rate
SerialAT.begin(19200);
delay(3000);
Serial.println(“Initializing modem…”);
modem.restart();
// Unlock your SIM card with a PIN
//modem.simUnlock(“1234”);
