Blynk Connects For 30 Seconds, Then Disconnects
I’ve updated my firmware, reinstalled the latest version of the app, simplified the program as much as possible, tried two different wifi networks, changed Config Preference max data output, and all that everything has resulted in is wanting to turn green like the Hulk.
Blynk App connects to wifi and server just fine but then times out after 30 seconds and disconnects.
Please HELP!
#define BLYNK_DEBUG
char auth[] = "auth code";
char ssid[] = "maybe";
char pass[] = "youknow";
int brightness = 0;
BLYNK_WRITE(V10)  // Runs when slider widget (on V10) is moved.  Set limits 0-1023 for ESP
  brightness = param.asInt();  // Get slider value.
  analogWrite(5, brightness);  // Send slider value to real LED on any PWM capable pin on your board
Not really surprising as you don’t have Blynk.run in your void loop.
You just saved my life Pete!
Thank you!
