Hi All,
- Arduino UNO
- Expansion Board (https://www.dfrobot.com/product-1009.html)
- Wifi Bee (https://www.dfrobot.com/product-1279.html)
- External 7.5V power supply, USB not connected
- Code:
#include <ESP8266_Lib.h>
#define EspSerial Serial
#define ESP8266_BAUD 9600
char auth[] = "b1e93fcd7117492a866NOPEda";
char ssid[] = "Dan's iPhone";
char pass[] = "######";
SoftwareSerial debugSerial(10, 11); // RX, TX
WidgetTerminal terminal(V0);
ESP8266 wifi(&EspSerial);
debugSerial.begin(9600);
debugSerial.println("test");
// Set ESP8266 baud rate
debugSerial.println("before connect");
Blynk.begin(auth, wifi, ssid, pass, "#######", 8080);
debugSerial.println("after connect");
terminal.println("Terminal print");
terminal.flush();
BLYNK_WRITE(V1)
terminal.println("PRESSED");
terminal.flush();
Now, it connects to my local Blynk server just fine and I can see the terminal print and if I press V1 quick enough, I can see “PRESSED”, but then it just disconnects for absolutely no reason and never connects again.
I slapped the expansion board onto an Arduino Mega just for the fun of it and everything is working perfectly fine, but as soon as I revert back to the UNO above behavior starts happening again.
Would you guys have an idea why that might be?
Cheers,
Dan
