Hi, I am having an issue never seen before and also solution is not available on community.
My program is working absolutely fine with Wi-Fi but creating issues while connecting with GSM. It is connected with blynk server for 2 to 3 minutes after starting the module but suddenly start disconnecting and connecting repeatedly (again and again).
Blynk app is also showing “device is connected” and “device is disconnected” error within a sec repeatedly.
Already bought 2 Airtel SIM from different companies but having same issue in both. Also called customer care and made them manually allow blynk-cloud.com allowed by IP and URL both. But all in vain up to now. I had an Airtel SIM before which was working perfectly on the same program without creating any disconnection issue.
• Hardware: TTGO TCALL ESP32 + GSM
• Communication Mode GSM
• Using Arduino IDE to program TTGO
• Blynk Library version TTGO TCALL ESP 32 + GSM
• I am using Blynk server (not local)
• Blynk Library version 1.0.1
• Windows 10 on Laptop
Code:
// Please select the corresponding model
#define SIM800L_IP5306_VERSION_20200811
// Select your modem:
#define TINY_GSM_MODEM_SIM800
#define TINY_GSM_RX_BUFFER 1024 // Set RX buffer to 1Kb
// Default heartbeat interval for GSM is 60
// If you want override this value, uncomment and set this option:
// #define BLYNK_HEARTBEAT 30
#include <TinyGsmClient.h>
char auth[] = "0ccNv_bqYS_trYpjfqd7jgmHVeRZuVGm";
// Your GPRS credentials
// Leave empty, if missing user or pass
char apn[] = "airtelgprs.com";
char user[] = "";
char pass[] = "";
// set GSM PIN, if any
// #define GSM_PIN "1234"
// Hardware Serial on Mega, Leonardo, Micro
#define SerialAT Serial1
// Set serial for debug console (to the Serial Monitor, default speed 115200)
#define SerialMon Serial
// See all AT commands, if wanted
// #define DUMP_AT_COMMANDS
// Define the serial console for debug prints, if needed
#define TINY_GSM_DEBUG SerialMon
// or Software Serial on Uno, Nano
//#include <SoftwareSerial.h>
//SoftwareSerial SerialAT(2, 3); // RX, TX
#include "utilities.h"
#define relay1 18
#define relay2 14
#define relay3 15
#define relay4 19
#ifdef DUMP_AT_COMMANDS
#include <StreamDebugger.h>
StreamDebugger debugger(SerialAT, SerialMon);
TinyGsm modem(debugger);
#else
TinyGsm modem(SerialAT);
#endif
TinyGsmClient client(modem);
BLYNK_WRITE(V0)
digitalWrite(relay1, !pinValue);
// process received value
BLYNK_WRITE(V1)
digitalWrite(relay2, !pinValue);
BLYNK_WRITE(V2)
digitalWrite(relay3, !pinValue);
BLYNK_WRITE(V3)
digitalWrite(relay4, !pinValue);
pinMode(relay1, OUTPUT);
pinMode(relay2, OUTPUT);
pinMode(relay3, OUTPUT);
pinMode(relay4, OUTPUT);
digitalWrite(relay1, HIGH);
digitalWrite(relay2, HIGH);
digitalWrite(relay3, HIGH);
digitalWrite(relay4, HIGH);
setupModem();
SerialMon.println("Wait...");
// Set GSM module baud rate and UART pins
SerialAT.begin(115200, SERIAL_8N1, MODEM_RX, MODEM_TX);
delay(6000);
SerialMon.println("Initializing modem...");
modem.restart();
// modem.init();
String modemInfo = modem.getModemInfo();
SerialMon.print("Modem Info: ");
SerialMon.println(modemInfo);
// Unlock your SIM card with a PIN
// modem.simUnlock("1234");
digitalWrite(13, HIGH); // Just for checking TTGO
delay(2000);
Serial.println("ON");
digitalWrite(13, LOW); // Just for checking TTGO
delay(2000);
Serial.println("OFF");
Utility file code:
#include <Wire.h>
#if defined(SIM800L_IP5306_VERSION_20190610)
#define MODEM_RST 5
#define MODEM_PWRKEY 4
#define MODEM_POWER_ON 23
#define MODEM_TX 27
#define MODEM_RX 26
#define I2C_SDA 21
#define I2C_SCL 22
#define LED_GPIO 13
#define LED_ON HIGH
#define LED_OFF LOW
#define IP5306_ADDR 0x75
#define IP5306_REG_SYS_CTL0 0x00
// setPowerBoostKeepOn
bool setupPMU()
bool en = true;
Wire.begin(I2C_SDA, I2C_SCL);
Wire.beginTransmission(IP5306_ADDR);
Wire.write(IP5306_REG_SYS_CTL0);
if (en) {
Wire.write(0x37); // Set bit1: 1 enable 0 disable boost keep on
Wire.write(0x35); // 0x37 is default reg value
return Wire.endTransmission() == 0;
#elif defined(SIM800L_AXP192_VERSION_20200327)
#define MODEM_RST 5
#define MODEM_TX 27
#define MODEM_RX 26
#define MODEM_DTR 32
#define MODEM_RI 33
#define I2C_SDA 21
#define I2C_SCL 22
#define LED_GPIO 13
#define LED_ON HIGH
#define LED_OFF LOW
#elif defined(SIM800C_AXP192_VERSION_20200609)
// pin definitions
#define MODEM_POWER_ON 25
#define MODEM_TX 27
#define MODEM_RX 26
#define MODEM_RI 33
#define I2C_SDA 21
#define I2C_SCL 22
#define LED_GPIO 12
#define LED_ON LOW
#define LED_OFF HIGH
#elif defined(SIM800L_IP5306_VERSION_20200811)
#define MODEM_RST 5
#define MODEM_TX 27
#define MODEM_RX 26
#define MODEM_RI 33
#define I2C_SDA 21
#define I2C_SCL 22
#define LED_GPIO 13
#define LED_ON HIGH
#define LED_OFF LOW
bool setupPMU()
bool en = true;
if (en) {
#else
#error "Please select the corresponding model"
#endif
#if defined(SIM800L_AXP192_VERSION_20200327) || defined(SIM800C_AXP192_VERSION_20200609)
#include <axp20x.h> //https://github.com/lewisxhe/AXP202X_Library
AXP20X_Class axp;
bool setupPMU()
// For more information about the use of AXP192, please refer to AXP202X_Library https://github.com/lewisxhe/AXP202X_Library
int ret = axp.begin(Wire, AXP192_SLAVE_ADDRESS);
if (ret == AXP_FAIL) {
Serial.println("AXP Power begin failed");
return false;
//! Turn off unused power
axp.setPowerOutPut(AXP192_DCDC1, AXP202_OFF);
axp.setPowerOutPut(AXP192_LDO2, AXP202_OFF);
axp.setPowerOutPut(AXP192_LDO3, AXP202_OFF);
axp.setPowerOutPut(AXP192_DCDC2, AXP202_OFF);
axp.setPowerOutPut(AXP192_EXTEN, AXP202_OFF);
//! Do not turn off DC3, it is powered by esp32
// axp.setPowerOutPut(AXP192_DCDC3, AXP202_ON);
// Set the charging indicator to turn off
// Turn it off to save current consumption
// axp.setChgLEDMode(AXP20X_LED_OFF);
// Set the charging indicator to flash once per second
// axp.setChgLEDMode(AXP20X_LED_BLINK_1HZ);
//! Use axp192 adc get voltage info
axp.adc1Enable(AXP202_VBUS_VOL_ADC1 | AXP202_VBUS_CUR_ADC1 | AXP202_BATT_CUR_ADC1 | AXP202_BATT_VOL_ADC1, true);
float vbus_v = axp.getVbusVoltage();
float vbus_c = axp.getVbusCurrent();
float batt_v = axp.getBattVoltage();
// axp.getBattPercentage(); // axp192 is not support percentage
Serial.printf("VBUS:%.2f mV %.2f mA ,BATTERY: %.2f\n", vbus_v, vbus_c, batt_v);
return true;
#endif
void setupModem()
// Start power management
if (setupPMU() == false) {
Serial.println("Setting power error");
#ifdef MODEM_RST
// Keep reset high
pinMode(MODEM_RST, OUTPUT);
digitalWrite(MODEM_RST, HIGH);
#endif
pinMode(MODEM_PWRKEY, OUTPUT);
pinMode(MODEM_POWER_ON, OUTPUT);
// Turn on the Modem power first
digitalWrite(MODEM_POWER_ON, HIGH);
// Pull down PWRKEY for more than 1 second according to manual requirements
digitalWrite(MODEM_PWRKEY, HIGH);
delay(100);
digitalWrite(MODEM_PWRKEY, LOW);
// Initialize the indicator as an output
pinMode(LED_GPIO, OUTPUT);
digitalWrite(LED_GPIO, LED_OFF);
