With NodeMCU everything is working fine. Only few ESPs are giving such issues.
As shown in snapshot started two ESP8266 with same code but different token for comparison - Testing 4.1 remains very unstable and keeps restarting while Testing 6.1 is very stable and works perfectly fine.
Have you checked power supplies and RSSI values that the boards are reporting?
What happens if you swap the boards so that 4.1 becomes 6.1 and vice versa, is it the actual board itself?
Have you examined them under a magnifier or microscope for physical problems?
Other issues could be network related, a lack of available DHCP IP addresses or reaching the maximum number of Wi-Fi connections for your router.
If you have multiple access points are all devices connecting to the same access point, or different ones?
Have you checked power supplies and RSSI values that the boards are reporting? [Vishal] - No haven’t checked that. But both have similar power supply. No difference technically which rules out this issue, I think.
What happens if you swap the boards so that 4.1 becomes 6.1 and vice versa, is it the actual board itself? [Vishal] - I will try this out. Good simple suggestion.
Have you examined them under a magnifier or microscope for physical problems? [Vishal] - No.
Other issues could be network related, a lack of available DHCP IP addresses or reaching the maximum number of Wi-Fi connections for your router. [Vishal] - I have investigated router but this not the problem. I have very good huawei 2.4 Ghz router
If you have multiple access points are all devices connecting to the same access point, or different ones? [Vishal] - I have one access point. Testing at home
I’m not suggesting that your router isn’t good, but if it’s been configured to use a small DCHP address pool then it it could quickly reach a point where it has too many connected devices, especially if addressed within that pool have been reserved for certain devices where you want them to have fixed IP addresses.
Believe me, some Blynkers have spent days trying to figure out why a device won’t connect in some circumstances, only to realise that they ran out of DHCP assigned IP addresses in some situations (when the wife and kids were come and their phones & tablets all connected to the network for example).
