What precisely does that mean. Once or twice a year, every few seconds?
Probably bad network at your end. Neighbour switched on his / her microwave etc.
Suggest you buy a few WeMos’ and run them alongside the nodeMCU as you shouldn’t need to reflash with new tokens. You might have a bad flash chip or you are just encountering the ESP reset bug. Do you make sure you do a manual reset after each flash? Is your ESP hooked up to Serial Monitor and if so any clues there?
no ESP reset or lost TOKEN, token just are invalid after sometimes… or after i reboot my network, i never get connection, only with new token… it’s bug in Blynk Server
