Blynk Configuration problem
Hey i was just trying to build a home automation system with the NEW Blynk platform when I got stuck with this error. I am using a node mcu for this.
When the node MCU is isolated and I upload the code it is able to successfully able to connect with the BLYNK servers, but when i connect it to my circuit it goes haywire and starts spitting out this output
[621] Using default config.
[621]
    ___  __          __
   / _ )/ /_ _____  / /__
  / _  / / // / _ \/  '_/
 /____/_/\_, /_[621] Hold the button for 10 seconds to reset configuration...
//_/[627] Hold the button for 10 seconds to reset configuration...
_/\_\[633] Hold the button for 10 seconds to reset configuration...
   [639] Hold the button for 10 seconds to reset configuration...
     /[645] Hold the button for 10 seconds to reset configuration...
___/ [651] Hold the button for 10 seconds to reset configuration...
v[656] Hold the button for 10 seconds to reset configuration...
1.1.0 on [663] Hold the button for 10 seconds to reset configuration...
NodeM[669] Hold the button for 10 seconds to reset configuration...
CU[675] Hold the button for 10 seconds to reset configuration...
[680] Hold the button for 10 seconds to reset configuration...
[686] Hold the button for 10 seconds to reset configuration...
 #St[692] Hold the button for 10 seconds to reset configuration...
andWithUkrai[698] Hold the button for 10 seconds to reset configuration...
[704] Hold the button for 10 seconds to reset configuration...
ne[710] Hold the button for 10 seconds to reset configuration...
[715] Hold the button for 10 seconds to reset configuration...
  [721] Hold the button for 10 seconds to reset configuration...
  [727] Hold the button for 10 seconds to reset configuration...
[732] Hold the button for 10 seconds to reset configuration...
h[738] Hold the button for 10 seconds to reset configuration...
ttps[744] Hold the button for 10 seconds to reset configuration...
:[749] Hold the button for 10 seconds to reset configuration...
//bit.ly/[756] Hold the button for 10 seconds to reset configuration...
swua
[762] Hold the button for 10 seconds to reset configuration...
[[768] Hold the button for 10 seconds to reset configuration...
768] [774] Hold the button for 10 seconds to reset configuration...
-----[780] Hold the button for 10 seconds to reset configuration...
--------------[787] Hold the button for 10 seconds to reset configuration...
[792] Hold the button for 10 seconds to reset configuration...
--[798] Hold the button for 10 seconds to reset configuration...
---[804] Hold the button for 10 seconds to reset configuration...
[81[810] Hold the button for 10 seconds to reset configuration...
0[815] Hold the button for 10 seconds to reset configuration...
] Pro[821] Hold the button for 10 seconds to reset configuration...
duct:  Ho[828] Hold the button for 10 seconds to reset configuration...
meUTO[834] Hold the button for 10 seconds to reset configuration...
MATION[840] Hold the button for 10 seconds to reset configuration...
[[846] Hold the button for 10 seconds to reset configuration...
846] Fi[852] Hold the button for 10 seconds to reset configuration...
rmwar[858] Hold the button for 10 seconds to reset configuration...
e:[864] Hold the button for 10 seconds to reset configuration...
 0.1.0 [870] Hold the button for 10 seconds to reset configuration...
(build[876] Hold the button for 10 seconds to reset configuration...
 Au[882] Hold the button for 10 seconds to reset configuration...
g 2[887] Hold the button for 10 seconds to reset configuration...
2 [893] Hold the button for 10 seconds to reset configuration...
2[899] Hold the button for 10 seconds to reset configuration...
02[904] Hold the button for 10 seconds to reset configuration...
2 18:15:18)
[[911] Hold the button for 10 seconds to reset configuration...
9[917] Hold the button for 10 seconds to reset configuration...
1[923] Hold the button for 10 seconds to reset configuration...
1] Device[929] Hold the button for 10 seconds to reset configuration...
:   N[935] Hold the button for 10 seconds to reset configuration...
ode[941] Hold the button for 10 seconds to reset configuration...
MCU @ 80MHz
The node mcu isn’t the problem because it works fine when it is not connected to anything but as soon as i connect it to the circuit it gives me this output
This is the code
#define BLYNK_TEMPLATE_ID "-------"
#define BLYNK_DEVICE_NAME "---------"
#define BLYNK_FIRMWARE_VERSION        "0.1.0"
//#define BLYNK_DEBUG
#define APP_DEBUG
// Uncomment your board, or configure a custom board in Settings.h
//#define USE_SPARKFUN_BLYNK_BOARD
#define USE_NODE_MCU_BOARD
//#define USE_WITTY_CLOUD_BOARD
//#define USE_WEMOS_D1_MINI
#include "BlynkEdgent.h"
int staterel1 = HIGH;
int staterel2 = HIGH;
int staterel3 = HIGH;
int staterel4 = HIGH;
int relay1 = 14;
int relay2 = 12;
int relay3 = 4;
int relay4 = 5;
BLYNK_CONNECTED(){
  Blynk.syncVirtual(V12);
  Blynk.syncVirtual(V13);
  Blynk.syncVirtual(V14);
  Blynk.syncVirtual(V15);
BLYNK_WRITE(V12)
  staterel1 = param.asInt(); // assigning incoming value from pin V1 to a variable
  digitalWrite(relay1, staterel1);
BLYNK_WRITE(V13)
  staterel2 = param.asInt(); // assigning incoming value from pin V1 to a variable
  digitalWrite(relay2, staterel2);
BLYNK_WRITE(V14)
  staterel3 = param.asInt(); // assigning incoming value from pin V1 to a variable
  digitalWrite(relay3, staterel3);
BLYNK_WRITE(V15)
  staterel4 = param.asInt(); // assigning incoming value from pin V1 to a variable
  digitalWrite(relay4, staterel4);
  pinMode(relay1, OUTPUT);
  pinMode(relay2, OUTPUT);
  pinMode(relay3, OUTPUT);
  pinMode(relay4, OUTPUT);
  Serial.println("Begin");
  delay(100);
  BlynkEdgent.begin();
  BlynkEdgent.run();
This is the schematic
Please can anyone help me with this.
Thanks in advance
Have you changed anything un your Settings.h tab?
Is the FLASH button on your NodeMCU pressed in? As this (by default) is the reset button that clears the provisioning and is what is being reported as being pressed in your serial monitor.
More info here…
nope have changed nothing in this file
also no, but even if it is the case why does it work when not connected to the circuit?
Node MCU is able to connect to my network and blynk server when not connected to the circuit.
I even tried another Node MCU the same thing happens
Dis you read the link I provided?
Do you have any digital pin datastreams set up in your template?
All I have are 4 virtual pins set up
Yeah
