I’m using Blynk’s python library, I have this code:
@blynk.VIRTUAL_WRITE(3)
def controlFans(value):
if int(value[0]) == 1:
print('> Fans turned on')
blynk.virtual_write(5, 'Fans on')
GPIO.output(RELAY1_PIN, GPIO.LOW)
else:
print('> Fans turned off')
blynk.virtual_write(5, 'Fans off')
GPIO.output(RELAY1_PIN, GPIO.HIGH)
def adjustHumidity():
hum, temp = checkSensorData()
logging.warning('Minimum humidity reached. Mist on. Temp: {} ,Hum: {}'.format(round(temp, 2),round(hum, 2)))
startTime = time.time()
blynk.virtual_write(5, 'Adjusting humidity')
flag = False
while flag == False:
GPIO.output(RELAY2_PIN, GPIO.LOW)
time.sleep(MIST_DURATION)
print('checking sensor on adjusting hum')
blynk.virtual_write(TEMP_VPIN, temp)
blynk.virtual_write(HUM_VPIN, hum)
if hum > MIN_HUM_VALUE:
print('> Done misting')
GPIO.output(RELAY2_PIN, GPIO.HIGH)
flag = True
blynk.virtual_write(5, 'Normal')
try:
while True:
blynk.run()
blynkTimer.run()
except KeyboardInterrupt:
blynk.disconnect()
Of course is not my full program because that is about 300 lines, but I will describe where my problem is briefly:
My program checks humidity value from a sensor using a blynk timer, every 15 seconds. If it reaches a given value, it calls the function ‘adjustHumidity()’, which, as its name says, adjust the humidity and checks again every 5 seconds, instead of the blynk timer (15s)
The problem is that while my program is in that function and AFTER it goes back to the main loop, the buttons I have stop working. They work when I just launch my program, but they just stop working after that point.
I would appreciate any help with this. Thanks in advance.
