Hello I am getting a “not allowed” error in my node red debug window. I have it installed on a raspberry pi.
See Picture
I forgot to say, could someone please help me?
To be honest, I cant see why you’re using the Bridge node here (actually, I don’t see the point of the Bridge node at all, it’s redundant as far as I’m concerned).
I have multiple connections set-up, that reflect the name I have to my devices in the app when I created them.
If I want Device A to update Device B then I just choose Device A as the write event connection and Device B as the write connection and it works fine.
But, in your case you aren’t even using a device to update another device, you’re simply using a inject node to update a pin on a device.
