Blynk Board DHT22
I want to connnect a humidity sensor DHT 22 to the Sparkfun Blynk Board
Here is a description for a Arduino Mega http://howtomechatronics.com/tutorials/arduino/dht11-dht22-sensors-temperature-and-humidity-tutorial-using-arduino/ but I am not sure if i can do the same with a Blynk Board. Should I follow the example given here: http://blog.filipeflop.com/wireless/economizar-agua-sparkfun-blynk-board.html
Thanks, Gernot
@Geab yes you can use DHT 22 with Blynk and the Sparkfun Blynk board.
The filipeflop blog is very much overkill for your needs but it might give you a guide.
I would search this site for “DHT 22” and the wider internet for “Blynk DHT22”.
The howtomechatronics site has almost all you need, just Blnkify the sketch they provide.
