Arduino UNO
connected via ESP 8266 via software serial.
The project works correctly on cloud servers using the following code Blynk.begin(auth, wifi, ssid, pass);
if I try to use the server in the house (raspberry 3) using the following code Blynk.begin(auth, wifi, ssid, pass, IPAddress(192,168,1,44), 8080);
and indicating the IP and the server port returns this error
error: 'IPAddress' was not declared in this scope
I just do not understand…
I do not understand why this error because using the same code with a WEMOS D1 mini the error does not appear and everything works correctly.
I’m still curious about what Data you’re passing into the ‘wifi’ variable, I’ve never seen Blynk.begin used with that extra parameter in there.
I don’t think the commas were the issue, you use points when it’s a string literal (enclosed between quotation marks), but commas when declaring a IPAddress type variable.
