After upgrading to Blynk 0.4.3 BLYNK_ATTACH_WIDGET(rtc, V30); won’t compile anymore.
I tried to upgrade from Arduino 1.6.9 to 1.8.1 with no effect.
Arduino:1.8.1 (Windows 7), Arduino Pro or Pro Mini, ATmega328 (5V, 16 MHz)"
src/Blynk/BlynkWidgetBase.h:43:9: error: 'class WidgetRTC' has no member named 'setVPin'
widget.setVPin(vPin);
I get the error even in the RTC-example if adding BLYNK_ATTACH_WIDGET(rtc, V30); directly after WidgetRTC rtc;
RTC widget now not connected to any pin. As it is only server side feature. It is separate Blynk command now. This was done due to conflicts with Device Selector widget.
