Blynk+ arduino uno+ esp8266
I want to use ESP8266 to connect to my Wifi (dont want to use as standalone), is there any way i can use it without updating ESP firmware.
I have searched for the topic where it suggested to use ESP8266_Shield_SoftSer example, but it is not available in the current library of Blynk from git hub.
I am just using ESP8266 module not the shield.
Kindly help me
I am trying with the code below:
> #include <ESP8266_HardSer.h>
> #include <BlynkSimpleShieldEsp8266_HardSer.h>
> #define BLYNK_PRINT Serial // Comment this out to disable prints and save space
>     #define EspSerial Serial
>     #define SSID "\"test\""
>     #define PASSWORD "\"wifi\""
>     ESP8266 wifi(EspSerial);
>     char auth[] = "xxxxxxxxxxxxxxxxxxxxxxxxxx";
>     const int analogInPin = A0;  // Analog input pin
>     const int analogInPin1 = A3;
>     const int analogInPin2 = A2;
>     // digital pin 2 has a pushbutton attached to it. Give it a name:
>     int gassensor = 2;
>     int ldr =3;
>     int sensorValue = 0;        // value read from the  temp
>     int sensorValue1 = 0;        // value read from the Hum
>     const int RPin1 =  13;
>     const int RPin2 =  12;
>     const int RPin3 =  11;
>     const int RPin4 =  10;
>     char inByte;
>     void setup() {
>       // initialize serial communications and wait for port to open:
>       Serial.begin(115200);
>         delay(1000);
>      EspSerial.begin(115200);
>      Serial.println("AT");
>     delay(500);
>      Serial.println("AT+RST");
>      delay(2000);
>      Serial.println("AT+CWJAP?");
>      delay(1000);
>       //Serial.println("AT+CWSAP="SSID","PASSWORD",3,0");
>     Serial.println("AT+CWJAP="SSID","PASSWORD"");
>       delay(15000);
>        Serial.println("AT+CIFSR");
>       delay(500);
>        Serial.println("AT+CIPMUX=1");
>       delay(500);
>        Blynk.begin(auth, wifi, "test", "wifi");
>       //delay(500);
>         ; // wait for serial port to connect. Needed for native USB port only
>       pinMode(gassensor, INPUT);
>       pinMode(ldr, INPUT);
>       pinMode(RPin1, OUTPUT);
>       pinMode(RPin2, OUTPUT);
>       pinMode(RPin3, OUTPUT);
>       pinMode(RPin4, OUTPUT);
>     void loop() {
>       unsigned char value;
>       unsigned int v;
>       float val,hum;
>     sensorValue = analogRead(analogInPin);
>      Blynk.run();
But no success…
Kindly oblige
It’s working for hardware serial connetion.
I strongly recommend to use the hardware serial
char auth[] = "xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx"; //walid auth
char ssid[] = "aaa";
char pass[] = "bbbbbb";
#include <ESP8266_Lib.h>
#define EspSerial Serial // Set ESP8266 Serial object
ESP8266 wifi(&EspSerial);
  Serial.begin(115200);  // Set console baud rate
  EspSerial.begin(115200);  // Set ESP8266 baud rate
Thank you for the reply.
I dont want to use ESP8266_Lib.h, as i want to use ESP8266 to connect the wifi network.
