Hello, so after my mobile app auto updated to version 2.27.3 (now i have turned the auto-update OFF), while i was viewing the super chart in fullscreen mode, all of a sudden it changed orientation to normal bylnk viewing screen, however TABS fonts got somehow enlarged!
i also then upgraded the local server (on the RPI3) just incase to match the latest update. however still the same as per the below image.
to reset i have to kill the app and relaunch each time it happens
So it happens after you exit from Super Chart fullscreen?
On
App checks for orientation changes on the screen - so if you move the screen from landscape it exits the fullscreen.
yes, so i am seeing the super chart full screen in horizontal position, as soon as i turn the mobile vertical it will automatically switches to the main app , and at that point it freaks a bit but reverting back and forth the superchart and the end result will be as the image. even if i close the super chart full screen from the top right side icon it will happen the same.
I have notice that this happens only when the mobile is turned into horizontal position but this is a necessity to analyse the super chart.
