Hi
I am trying to get working this code.
I am using Photon .
I am new at Blynk and Arduino style of programming, I use to program in C.
This code is for sending from external microcontroller the same string periodically to Blynk app just for test.
The The photon and the external Mcu are hooked up through RX-TX pins respectively
The string is “<126.78>”.
Same code snippet has been adapted from Arduino tutorials:
http://forum.arduino.cc/index.php?topic=288234.0
The point is that the code compile well and also flash successful but nothing happens on Label Display
I set it up on Blynk app hooked up to virtual pin V5.
Hope for some help.
Here it is the code.
Thank you.
http://twitter.com/blynk_app
#define BLYNK_PRINT Serial1
#include <blynk.h>
char auth[] = "xxxxxxxxxxxx41089e112c6f5b2xxxxx";
const byte numChars = 8;
char receivedChars[numChars];
boolean newData = false;
Serial1.begin(56700);
delay(5000); // Allow board to settle
Blynk.begin(auth);
timer.setInterval(2000L, sendAmp);
sendAmp();
void sendAmp(){
recvWithStartEndMarkers();
// Send it to the server
Blynk.virtualWrite(V5, receivedChars);
void recvWithStartEndMarkers() {
static boolean recvInProgress = false;
static byte ndx = 0;
char startMarker = '<';
char endMarker = '>';
char rc;
while (Serial.available() > 0 && newData == false) {
rc = Serial.read();
if (recvInProgress == true) {
if (rc != endMarker) {
receivedChars[ndx] = rc;
ndx++;
if (ndx >= numChars) {
ndx = numChars - 1;
else {
receivedChars[ndx] = '\0'; // terminate the string
ndx = 0;
newData = true;
else if (rc == startMarker) {
recvInProgress = true;
