Hello everyone. My Blynk App is showing “wasn’t online yet”. Iam simulating sensors in Proteus and wish to see the values in Blynk App. I have connected my Arduino UNO board with the compim component with the arduino being set as COM3 and Blynk cloud assigned as COM4.
#define BLYNK_PRINT SwSerial
#include <DHT.h>
char auth[] = "kt1CjwrL10ynqJxY93i5-GZWO_VwfeM-";
#define DHTPIN 2 // What digital pin we're connected to
//#define DHTTYPE DHT22 // DHT 22, AM2302, AM2321
//#define DHTTYPE DHT21 // DHT 21, AM2301
DHT dht(DHTPIN, DHTTYPE);
void sendSensor()
float h = dht.readHumidity();
if (isnan(h) || isnan(t)) {
SwSerial.println("Failed to read from DHT sensor!");
return;
Blynk.virtualWrite(V5, h);
Blynk.virtualWrite(V6, t);
SwSerial.begin(9600);
Blynk.begin(Serial, auth);
dht.begin();
I have tried switching networks, specifying server IP but that hasn’t worked. I don’t understand what more I can try. Please help
EDIT: I have also checked my auth code many times and have disabled my firewall to no effect
EDIT 2: I have somehow managed it to get online. However I can’t display values on my Value Display
