Blynk app gives wrong temperature and humidity reading
I used this code to read DHT11 and push it to virtual pin 1 and 3 to then graph it in a SuperChart by using 2 data streams.
Maybe this can help.
hook up the DHT to gpio as indicated here
import RPi.GPIO as GPIO
import time
import Adafruit_DHT
import BlynkLib
GPIO.setmode(GPIO.BCM)
GPIO.setwarnings(False)
BLYNK_AUTH = 'your auth code'
blynk = BlynkLib.Blynk(BLYNK_AUTH)
def readHandT():
    sensor_type = Adafruit_DHT.DHT11
    sensor_pin = 2
    localtime = time.asctime( time.localtime(time.time()) )
    humidity, temperature = Adafruit_DHT.read_retry(sensor_type, sensor_pin)
    if humidity is not None and temperature is not None:
        print(localtime,' Humidity = {:.2f}%\tTemperature = {:.2f}C'.format(humidity, temperature))
        blynk.virtual_write(1, temperature)
        blynk.virtual_write(3, humidity)
    else:
        print("could not get data from DHT")
def wait(wachttijd):
    print(wachttijd,"sec zzzzzzz")
    i=wachttijd
    while i>0:
        time.sleep(1)
        i=i-1
try: #probeer de volgende statements tenzij 'except' op deze hoogte
    blynk.run()
    print("start")
    while 1:
        readHandT()
        wait(2)
except KeyboardInterrupt:
    GPIO.cleanup()
have fun
you can map H and T every 2 seconds. change to wait(60) if you want it every minute.
Still need to find out how to capture the broken pipe error 32 and recover from it, but that’s for later.
