hy my this sketch run succesfully on python
import Adafruit_DHT
import BlynkLib
import time
sensor=Adafruit_DHT.DHT11
gpio=17
BLYNK_AUTH=’ c8622877538a49258f2d0202ea136c64’
blynk=BlynkLib.Blynk(BLYNK_AUTH)
humidity,temperature=Adafruit_DHT.read_retry(sensor,gpio)
if humidity is not None and temperature is not None:
print (‘Temp={0:0.1f}*C Humidity={1:0.1f}%’.format(temperature,humidity))
@blynk.VIRTUAL_WRITE(2)
def my_write_handler(value):
print(‘Current V1 value: {}’.format(value))
@blynk.VIRTUAL_READ(2)
def my_read_handler():
blynk.virtual_write(1, time.ticks_ms() // 1000)
blynk.run()
else:
print (‘Failed to get reading.Try again!’)
but my blynk app does not receive any reading
I used this code to read DHT11 and push it to virtual pin 1 and 3 to then graph it in a SuperChart by using 2 data streams.
Maybe this can help.
hook up the DHT to gpio as indicated here
import RPi.GPIO as GPIO
import time
import Adafruit_DHT
import BlynkLib
GPIO.setmode(GPIO.BCM)
GPIO.setwarnings(False)
BLYNK_AUTH = 'your auth code'
def readHandT():
sensor_type = Adafruit_DHT.DHT11
sensor_pin = 2
localtime = time.asctime( time.localtime(time.time()) )
humidity, temperature = Adafruit_DHT.read_retry(sensor_type, sensor_pin)
print(localtime,' Humidity = {:.2f}%\tTemperature = {:.2f}C'.format(humidity, temperature))
blynk.virtual_write(1, temperature)
blynk.virtual_write(3, humidity)
else:
print("could not get data from DHT")
def wait(wachttijd):
print(wachttijd,"sec zzzzzzz")
i=wachttijd
while i>0:
time.sleep(1)
i=i-1
try: #probeer de volgende statements tenzij 'except' op deze hoogte
blynk.run()
print("start")
while 1:
readHandT()
wait(2)
except KeyboardInterrupt:
GPIO.cleanup()
have fun
you can map H and T every 2 seconds. change to wait(60) if you want it every minute.
Still need to find out how to capture the broken pipe error 32 and recover from it, but that’s for later.
