My Blynk App is getting disconnected frequently. When I first open my Blynk app, the project runs fine for 2 mins and then again goes offline. I have attached the Screen shot of my blynk app and attached my code as well. Pleasssssse help ASAP. Please find below the hardware and software details and the sketch code.
Arduino UNO with ESP8266 Wifi Shield
Smartphone OS + version : Android 7.1.1
Blynk Server
Blynk Library version: Blynk_Release_v0.5.2
Sketch code:::::
WARNING!
It’s very tricky to get it working. Please read this article:
http://help.blynk.cc/hardware-and-libraries/arduino/esp8266-with-at-firmware
This example shows how to synchronize Button widget
and physical button state.
App project setup:
Button widget attached to V2 (Switch mode)
#include <ESP8266_Lib.h>
char auth[] = “**********************************”; //encrypted
// Set password to “” for open networks.
char ssid[] = “*******”; //encrypted
char pass[] = “”;
// Hardware Serial on Mega, Leonardo, Micro…
#define EspSerial Serial
// or Software Serial on Uno, Nano…
//#include <SoftwareSerial.h>
// Your ESP8266 baud rate:
#define ESP8266_BAUD 115200
ESP8266 wifi(&EspSerial);
// Set your LED and physical button pins here
const int ledPin = 7;
const int btnPin = 8;
void checkPhysicalButton();
int ledState = LOW;
int btnState = HIGH;
// Every time we connect to the cloud…
BLYNK_CONNECTED() {
//Blynk.syncVirtual(V2);
// Alternatively, you could override server state using:
btnState = digitalRead(btnPin);
Blynk.virtualWrite(V2, btnState);
// When App button is pushed - switch the state
BLYNK_WRITE(V2) {
ledState = param.asInt();
digitalWrite(ledPin, ledState);
if (digitalRead(btnPin) == LOW) {
if (btnState != LOW) {
// Toggle LED state
// ledState = !ledState;
//digitalWrite(ledPin, ledState);
btnState= !btnState;
// Update Button Widget
btnState = LOW;
btnState = HIGH;
// Set ESP8266 baud rate
//Blynk.begin(auth, wifi, ssid, pass, “blynk-cloud.com”, 80);
//Blynk.begin(auth, wifi, ssid, pass, IPAddress(192,168,1,100), 8080);
pinMode(ledPin, OUTPUT);
pinMode(btnPin, INPUT_PULLUP);
// Setup a function to be called every 100 ms
timer.setInterval(100L, checkPhysicalButton);
