I am using this app on my android mobile to monitor some sensors and control some outlets, found amazing, very helpful and user friendly.
I have one suggestion/need, if you make this app for computers (Windows etc) then it will be great optional source for everyone to use either mobile or pc.
Your efforts will be highly appreciated.
i am already using emulator to run blynk app over pc but it is not the best solution.
I also created an app with C# visual studio for pc, works fine but after i found blynk app which is only for mobiles, i thought, if this blynk can have for pc then it will be very useful.
In emulator, it shows only a small display like mobile which is not so attractive but functioning.
functions are main things but look matters too.
Blynk is IOT and designed to run on mobiles… thus that is the base screen real estate it works within. This is normal.
Even if the Developers come up with a desktop GUI, they somehow need to maintain continuity between what is seen on the PC and what is on the mobile… so don’t get your hopes up for 4k Blynk displays quite yet
The OP didn’t like the emulator because it is the same screen layout as all phones (as is normal)… this emulator will not be any different in appearance.
I was going to try it out, but $136/year? And I didn’t see any free option, just a trial option.
Ah, wait… it doesn’t matter for me anyhow, it is not fully compatible with Windows 10 yet. I will stick with MEmu then.
Haha… nope, not sleeping any more so than normal… 10-12 hours a day is sufficient Not including being only half alert the rest of the time
But I did hit a realisation that I was spending too much time here trying to keep order… even if only for my own sense of aesthetics.
As for the “new” platform… well… I started using Blynk as a great GUI for MCUs… but it is morphing into somthing rather different, and only time will tell if it will be worth my further energy investment.
So, for now I putter on other projects and only pop in once and awhile to see what’s up.
Keep up the good work @PeteKnight but don’t burn out
