Lookin at your photo again closely, it looks like you have the relay on the left (in the photo) wired incorrectly, the power/gnd wires look reversed? (At the regulator)
you are right!
the left relay is wired incorrectly.
but the right relay is ok.
Moreover, that battery is really power limited, it would be better using a proper power supply.
yeah ! I did not think about it !
9V battery delivers only 500 mA !!
and he use a regulator …
The relays should only draw around 100-200mA each but connecting the one the wrong way may be dragging the voltage down too low.
@Sreehari, can you connect the relays back as you had before using the VU pin and post a picture? It should work better using the 2A 5v power supply.
Edit: - Without the voltage regulator…
