Blynk app disconnects when button is pressed
I’m trying to implement a home automation project as given in the following link
Instead of the 4 channel relay, I’m using 2 single channel relays.
I load the ESP8266_Standalone example with my auth code,ssid and password.
Im using D3,D4 pins of the nodemcu to control the relays, and Im powering the relays using the 5V supply from nodemcu.
When I press any of the buttons the Blynk app disconnects.
There is no change in the relays when the buttons are pressed.
Please provide me a solution to make the home automation system using blynk app and node mcu.
to help you we need to see your sketch :wink:
    Follow us:                  http://www.fb.com/blynkapp
                                http://twitter.com/blynk_app
  This example runs directly on ESP8266 chip.
  Please be sure to select the right ESP8266 module
  in the Tools -> Board menu!
char auth[] = "my auth code";
char ssid[] = "wifi";
char pass[] = "passwd";
i think it’s caused by pin you are using.
I don’t see any pinout declaration, no more virtual write or digital write in your sketch.
I was proceeding in accordance with the youtube video,i m newbie to Blynk.
ok , but the sketch you provide trigges nothing.
I think it’s not the sketch you are using.
what do you see on the serial monitor?
[58] Connecting to xxxx
[1062] Connected to WiFi
[1062] IP:xxxxxxxxxxxx
[1062]
/ _ )/ /_ _____ / /__
/ _ / / // / _ / '/
//_, /////_
__/ v0.6.1 on NodeMCU
[1139] Connecting to blynk-cloud.com:80
[1721] Ready (ping: 262ms).
Without the triggers how is the person in the video still able to work the relays ?
he did that with Google API, not blynk.:joy:
your sketch do nothing else connect to blynk server.
How can I connect to blynk server?
as @Gunner will say, you have to learn before blynk from zero before trying to ask Google to trigger your relay. :wink:
i think , my friend @PeteKnight will be the best to teach you about IFTT :slight_smile:
I changed by code, first I need to control the relays just using the blynk app.So the changed code is as follows:
char auth = “my auth code”;
// Set password to “” for open networks.
char ssid = “wifi”;
char pass = “wifi passwd”;
const int Relay_1 = D1;
const int Relay_2 = D2;
pinMode(Relay_1, OUTPUT);
pinMode(Relay_2, OUTPUT);
digitalWrite(Relay_1, HIGH);
digitalWrite(Relay_2, HIGH);
/********************** Relay 1 ON/OFF V1 *******************************/
BLYNK_WRITE(V1)
int pinValue = param.asInt();
if (pinValue == 1)
digitalWrite(Relay_1, LOW);
Serial.println(“Relay 1 On”);
else if (pinValue == 0)
Serial.println(“Relay 1 Off”);
/********************** Relay 2 ON/OFF V2 *******************************/
BLYNK_WRITE(V2)
if (pinValue == 1)
digitalWrite(Relay_2, LOW);
Serial.println(“Relay 2 On”);
Serial.println(“Relay 2 Off”);
Still, the problem persists, whenever I’m clicking on the button widget, the project disconnects. But, I’m getting the serial prints but there is no change in the relays.
Heres the serial monitor output :
[57] Connecting to xxxx
[1061] Connected to WiFi
[1061] IP: xxxxxxx
[1061]
___ __ __
/ _ / / // / _ / '/
//_, /////_
[1138] Connecting to blynk-cloud.com:80
[1709] Ready (ping: 261ms).
Relay 2 Off
Relay 1 Off
Relay 2 On
Relay 1 On
Relay 2 Off
Relay 1 Off
Probably not the best idea.
nodemcu provide 5v volts coming directly from power supply, so no worry.
I have 4 relays on my nodemcu.
they work well.
my power supply is an USB 2A adapter for phone.
Alex.
It it depends what @Sreehari is using for power, and what type of relays he’s using.
Im using the following relay
relay
and my power supply is USB 2A adapter for phone.
If you power the Nodemcu trough micro-usb, you must power the relay from VU pin NOT from VIN pin…
Which pin are you referring to?
The NodeMCU doesn’t have a pin labelled VU.
