I am facing this weird problem. As soon as i click on the time input widget, the app crashes (IOS). I tried force closing the app and tried the same again, but the app crashes every time. The app is updated too.
I have already sent the logs. Please let me know if the logs are sent.
Thank you.
Edit
One more weird thing is, this is happening only with one widget(V1) on one particular template. The other time input widget attached to V2…V4 is working fine.
I tried deleting the datastream and setting it up again. But that dint help either.
Thank you for the report. Looks like the value was set with Android version? Anyway, the crash cause will be fixed in the next app update.
To reset the datastream value try the “Erase Latest Value” command from Actions menu in Datastreams section of the device details opened in Web Console.
