Hello, I just wanted to share this sketch with someone who needs it. It is for the tof10120 time of flight sensor to work with blynk. have fun with it.
#include <WiFi.h>
#include <WiFiClient.h>
#include <BlynkSimpleEsp32.h>
#include <Wire.h>
char auth[] = "";
char ssid[] = "";
char pass[] = "";
void myTimerEvent()
Blynk.virtualWrite(V6, millis() / 1000);
unsigned char ok_flag;
unsigned char fail_flag;
unsigned short lenth_val = 0;
unsigned char i2c_rx_buf[16];
unsigned char dirsend_flag=0;
void mydistanceEvent()
int x=ReadDistance();
Serial.print(x);
Serial.println(" mm");
Blynk.virtualWrite(V7, x);
Blynk.virtualWrite(V8, x);
int serial_putc( char c, struct __file * )
Serial.write( c );
return c;
void printf_begin(void)
void SensorRead(unsigned char addr,unsigned char* datbuf,unsigned char cnt)
unsigned short result=0;
// step 1: instruct sensor to read echoes
Wire.beginTransmission(82); // transmit to device #82 (0x52)
// the address specified in the datasheet is 164 (0xa4)
// but i2c adressing uses the high 7 bits so it's 82
Wire.write(byte(addr)); // sets distance data address (addr)
Wire.endTransmission(); // stop transmitting
// step 2: wait for readings to happen
delay(1); // datasheet suggests at least 30uS
// step 3: request reading from sensor
Wire.requestFrom(82, cnt); // request cnt bytes from slave device #82 (0x52)
// step 5: receive reading from sensor
if (cnt <= Wire.available()) { // if two bytes were received
*datbuf++ = Wire.read(); // receive high byte (overwrites previous reading)
*datbuf++ = Wire.read(); // receive low byte as lower 8 bits
int ReadDistance(){
SensorRead(0x00,i2c_rx_buf,2);
lenth_val=i2c_rx_buf[0];
lenth_val=lenth_val<<8;
lenth_val|=i2c_rx_buf[1];
delay(300);
return lenth_val;
Wire.begin();
Serial.begin(9600,SERIAL_8N1);
printf_begin();
timer.setInterval(20000L, myTimerEvent);
timer.setInterval(2000L, mydistanceEvent);
