BLYNK
BLYNK.IO       ๐Ÿ“ฒ GETTING STARTED       ๐Ÿ“— DOCS       โ“HELP CENTER       ๐Ÿ‘‰ SKETCH BUILDER
Blynk and Timers
Does anyone know how many timers I can add in the void loop function without causing problems?
timer_trend.run();
timer_dht_hum.run();
timer_dht_temp.run()
Why do you want to put 4 timers in the loop ? only one is needed :scream:
you can have up to 16 timers for each timer object !
Thank you. Not sure why I thought there was only one timer per object using the Blynk timer. :thinking:
