Hello, I hope you are well
I have a question
I am a beginner with using blynk and I want to know if it is possible to control the circuit switch with blink
Can you clarify what you’re asking?
Are you wanting to control a relay?
I have a project on heartbeat and thermometer
the role of switch is when it opens the calculation of the number of filltred beats is stopped
and I want to know is it possible to control the switch in the proteus using app blynk ?
If the switch is controlled via a pin on the MCU then yes, otherwise I think the answer is probably no.
If you already have an physical switch doing this for you, then you can remove the switch and connect a relay which does the switching like the switch. This relay will be controlled by a WIFI device like a nodemcu or wemos.
