Blynk and SIM7600
Hi there,
I have created some projects with the SIM800L modules, and they work fine. But in our country all 2G networks will be shut down, the operators will reuse the frequencies for there new 5G network.
So Iam searching for an alternative, and right now I am looking at the SIM7600E module. But this module is not working with Blynk, but its supported in TinyGSM.
Iam able to get an GPRS connection, after that the sketch is trying to connect to Blynk. Thats failing.
Is there someone who has this setup already working?? I need some help with this…
Regards Chris
And what error are you receiving once you have the GPRS connection ?
The Serial Monitor says ā€œTrying to Connect to Blynkā€ā€¦ And thats not working and the Arduino MKRZero will reset after some time.
Regards Chris
10:42:02.028 -> [14020]
10:42:02.028 ->     ___  __          __
10:42:02.028 ->    / _ )/ /_ _____  / /__
10:42:02.028 ->   / _  / / // / _ \/  '_/
10:42:02.028 ->  /____/_/\_, /_//_/_/\_\
10:42:02.028 ->         /___/ v0.6.1 on MKRZERO
10:42:02.028 ->
10:42:02.028 -> [14020] Modem init...
10:42:02.028 -> [14031] Connecting to network...
10:42:02.062 -> [14045] Network: T-Mobile  NL T-Mobile  NL
10:42:02.062 -> [14045] Connecting to smartsites.t-mobile.nl ...
10:42:02.131 -> [14108] Connected to GPRS
10:42:02.131 -> [14133] Connecting to blynk-cloud.com:80
This the Serial Debug output, after this the Sketch freezes.
I’m using the Sim7000 with Blynk (Tinygsm) works very well.
The Sim7000 is an iot specific chipset, good coverage, but lower speed.
I’m using the SIM 7000E module from AND technology, with a Teensy 3.6.
Hi Lucifer,
Are you using NB-IOT or just the 3G network. I need roaming within Europe. The current NB-IOT networks doesn’t support roaming.
The needed bandwith is not that high, but i need to send also messages to the remote Hardware. This is often limited to 4 message per day, in the NB-IOT network.
Regards Chris
I’m only using the Sim7000 in Denmark at the moment.
Using the network of ā€˜3’, often it roams throu ā€˜yousee’ operator, especialy in the countryside where I live.
I only use Blynk, but I send quite some traffic, updating once a second.
Even the gprs mode gives acceptable speed, with ping time of 190mS.
Br Rasmus
Hi Rasmus,
Did you change the BlynkGsmClient.h for that, the SIM7000 is not listed in there?
Can you share the part of your sketch, where you address the use of an SIM7000??
That would be very helpfull for me.
If have also tried an SIM5360 and that gives me the same result. Connected to GPRS, but no connection made to the Blynk server.
Regards
Hi chr.keijzer
No I found the tinygsm lib, with Blynk integrated.
Br Rasmus
I do not use Wi-fi at the moment, on my todo list is. Make a ā€œIf Wifi is lost switch to LTEā€
I’m not the hardcore programmer, my good friend Jesper is doing all the heavy stuff.
My code:
[Unformatted code removed by moderator - please repost using triple backticks]
Hi Rasmus,
Your code is deleted by the moderator, not the correct format…
Chris
OK, what kind of format should it be in?.
I’m HW tech specialist not a ā€˜coder’
Br Rasmus
My code now formatted.
#pragma GCC diagnostic ignored "-Wwrite-strings"
#define TINY_GSM_MODEM_SIM7000
#define TINY_GSM_MODEM_ESP8266
#define RA8876_CS 15
#define RA8876_RESET 17
#define RA8876_BACKLIGHT 20
#define SD_SELECT BUILTIN_SDCARD
#define NUM_VALUES 29
#define BUFFER_SIZE 60
#define SerialMon Serial
#define SerialAT Serial4
#define DOUBLE_BUFFER_1  PAGE1_START_ADDR
#define DOUBLE_BUFFER_2  PAGE2_START_ADDR
#define CHARGER_CONNECTED 26
#define CHARGE_WIRE_ENABLE_1 35
#define CHARGE_WIRE_ENABLE_2 36
#define CHARGE_WIRE_ENABLE_3 37
#define CHARGE_SOLAR_ENABLE_1 51
//#define DEBUG_1
#define DEBUG_2
#include "RA8876.h"
#include <DS1307RTC.h>
#include <IniFile.h>
#include <SensorModbusMaster.h>
#include <SD.h>
#include <DS18B20.h>
#include <BME280I2C.h> //Bosch BME 280Temp, Humidity, Barometric Presure.
#include <Wire.h>
#include <TinyGsmClient.h>
#include <Adafruit_SleepyDog.h>
#include <EEPROM.h>
#include <TimeLib.h>
enum DISPLAY_TYPE {ADVANCED, SIMPLE};
const char apn[] = "data.tre.dk";
const char user[] = "";
const char pass[] = "";
const char wifiSSID[] = "Gigabyte_2.4Ghz";
const char wifiPass[] = "Spirill1111";
const char auth[] = "dd6a78ac747e4f99aedadd96d9862792";
BME280I2C bme;
DS18B20 ds(22);        // Pin used for DS18B20 sensor(s)
TinyGsm modem(SerialAT);
HardwareSerial modbusSerial = Serial1; //RS485 using UART1
modbusMaster modbus;
RA8876 tft = RA8876(RA8876_CS, RA8876_RESET);
IntervalTimer Timer1Second;
IntervalTimer Timer10Second;
IntervalTimer Timer60Second;
tmElements_t RTC_Clock_Data;
int ACTIVE_FRONT_BUFFER = DOUBLE_BUFFER_1;
int ACTIVE_BACK_BUFFER  = DOUBLE_BUFFER_2;
DISPLAY_TYPE ACTIVE_DISPLAY_TYPE = ADVANCED;
float Cabin_temp = 0;           //Bosch BME 280 Temperature
float Cabin_humidity = 0;       //Bosch BME 280 Humidity
float Cabin_barometric_presure; // Bosch barometric presure
int Rear_battery_temp = 0;      //Rear battery pack DS18B20 temp sensor.
int MainSoc = 25;
int FrontBattTemp = 0;
int RearBattTemp = 0;
int MotorTemp = 0;
int ContTemp = 0;
int DcDcTemp = 0;
int OutsideTemp = 0;
int DriveCurrent = 255;
int MainBatvoltage = 86;
int Charge1Current = 19;
float Charge2Current = 6.1;
float LowVoltVoltage = 13.6;
float AuxCurrent = 3.2;
int topPos = 0;
int MaxHeight = 285;
int TopLinePos = 200;
int GraphWidth = 22;
int ColumBegin = 98;
int ColumWidth = 10;
int ColumSpacing = 28;
int ColumBottom = 560;
int LastDrawnValues = 0;
float TotalVolatageTracktionBattery = 0;
int txtLine1 = 10;
int txtLine2 = 45;
int txtLine3 = 80;
int txtLine4 = 115;
int txtLine5 = 150;
int txtLine6 = 185;
int txtLine7 = 220;
int txtLine8 = 255;
int txtColumn1 = 10;
int txtColumn2 = 350;
int txtColumn3 = 690;
bool ledState = false;
char ClockBuffer[100];
int Voltage_divider = 194; //269
int ADC_ChannelEnable[] = {0, 0, 0, 0};
int ADC_Sensitivity[] = {0, 0, 0, 0};
float ADC_Sensitivity_Final[] = {0.0, 0.0, 0.0, 0.0};
int ADC_ZERO_Volt[] = {0, 0, 0, 0};
double Watts[] = {0.0, 0.0, 0.0, 0.0};
double TotalCharge[] = {0.0, 0.0, 0.0, 0.0};
uint16_t AmpRawValue[] = {0, 0, 0, 0};
double AmpCompensatedValue[] = {0.0, 0.0, 0.0, 0.0};
double AmpHours[] = {0.0, 0.0, 0.0, 0.0};
float AmpHoursTotal = 0.0;
double AverageAmps[] = {0.0, 0.0, 0.0, 0.0};
double WattHours[] = {0.0, 0.0, 0.0, 0.0};
float WattHoursTotal = 0.0;
int NumberOfSampels = 0;
bool ChargerConnected = false;
bool ChargerPreviouslyConnected = false;
int TimeSinceLastChargingStatusChange = 0;
double BatteryMaxMiliAmpHours = 0;
int numberOfChargersEnabled = 0;
int chargersDutyCyclePercent = 0;
int ChargingPWMIndex = 0;
double MAX_AMP_HOURS = 120;
int ChargerMaxMiliAmpOutput = 18000;
bool DoFullCharge = false;
int endTimeDay = 0;
int endTimeHour = 0;
int endTimeMinute = 0;
int CellActive[NUM_VALUES + 1];
float CellValue[NUM_VALUES + 1];
float CellVoltage[NUM_VALUES + 1];
uint16_t BleedValues[NUM_VALUES + 1];
float Current[4];
double RUNTIME = 0.0;
double LAST_RUNTIME = 0.0;
int Device64Active = 0;
int Device65Active = 0;
float totalcellvoltage = 0;
int Next_delay = 0; //RS485 SLAVE ID read delay
int graph6 = 0;
int CellBeginL = 100;
int TxtBeginL = 10;
int CellSpacing = 28;
int TotalVoltage = 0;
BLYNK_WRITE(V3) {  //Reset battery state command from blynk
  Serial.println("Setting charging finish time");
 TimeInputParam t(param);
 if (t.hasStartTime())
  endTimeHour = t.getStartHour();
  endTimeMinute = t.getStartMinute();
  for(int i = 0; i <7 ; i++){
    if( t.isWeekdaySelected(i) ){
      Serial.println("Weekday");
      Serial.println(RTC_Clock_Data.Wday);
      endTimeDay = i;
  Serial.println(String("Start: ") +
                   t.getStartHour() + ":" +
                   t.getStartMinute() + ":" +
                   t.getStartSecond());
  else if (t.isStartSunrise())
    Serial.println("Start at sunrise");
  else if (t.isStartSunset())
    Serial.println("Start at sunset");
    // Do nothing
  // Process stop time
  if (t.hasStopTime())
    Serial.println(String("Stop: ") +
                   t.getStopHour() + ":" +
                   t.getStopMinute() + ":" +
                   t.getStopSecond());
  else if (t.isStopSunrise())
    Serial.println("Stop at sunrise");
  else if (t.isStopSunset())
    Serial.println("Stop at sunset");
    // Do nothing: no stop time was set
BLYNK_WRITE(V10) {  //Reset battery state command from blynk
  Serial.println("Resetting battery level");
 for (int i = 0; i < 4; i++)
    if (ADC_ChannelEnable[i])
      AmpHours[i] = 0;
      WattHours[i] = 0;
void update_ADC_Values(int modbus_ID){
  modbus.begin(modbus_ID, modbusSerial, 2);
      AmpRawValue[i] = modbus.uint16FromRegister(0x03, i, bigEndian);
      ADC_Sensitivity_Final[i] = ADC_Sensitivity[i] / 100.0;
      AmpCompensatedValue[i] = AmpRawValue[i] - ADC_ZERO_Volt[i];
      AmpCompensatedValue[i] /= ADC_Sensitivity_Final[i];
      //BOSS: TESTCODE
      AmpCompensatedValue[i] = 4.0;
      Watts[i] = AmpCompensatedValue[i] * TotalVolatageTracktionBattery;
      TotalCharge[i] += AmpCompensatedValue[i];
      AmpHours[i] = TotalCharge[i] * (RUNTIME - LAST_RUNTIME);
      AmpHoursTotal += AmpHours[i];
      WattHours[i] = TotalVolatageTracktionBattery * AmpHours[i];
      WattHoursTotal += WattHours[i];
#ifdef DEBUG_1
      Serial.print("=");
      Serial.println(TotalVolatageTracktionBattery);
      Serial.println(AmpHours[i]);
      Serial.println(RUNTIME);
      Serial.println(AmpCompensatedValue[i], 1);
#endif
  LAST_RUNTIME = RUNTIME;
void set_BLEED_Values(){
  for (int i = 1; i <= NUM_VALUES; i++)
    if(CellActive[i] ){
      modbus.begin(CellActive[i], modbusSerial, 2);
      modbus.uint16ToRegister(20, BleedValues[i], bigEndian);
void printErrorMessage(uint8_t e, bool eol = true){
  switch (e)
  case IniFile::errorNoError:
    Serial.print("no error");
    break;
  case IniFile::errorFileNotFound:
    Serial.print("file not found");
    break;
  case IniFile::errorFileNotOpen:
    Serial.print("file not open");
    break;
  case IniFile::errorBufferTooSmall:
    Serial.print("buffer too small");
    break;
  case IniFile::errorSeekError:
    Serial.print("seek error");
    break;
  case IniFile::errorSectionNotFound:
    Serial.print("section not found");
    break;
  case IniFile::errorKeyNotFound:
    Serial.print("key not found");
    break;
  case IniFile::errorEndOfFile:
    Serial.print("end of file");
    break;
  case IniFile::errorUnknownError:
    Serial.print("unknown error");
    break;
  default:
    Serial.print("unknown error value");
    break;
  if (eol)
    Serial.println();
void myTimerEvent(){
  Blynk.virtualWrite(V5, TotalVolatageTracktionBattery);
void layout_advanced(){
  tft.canvasImageStartAddress(ACTIVE_BACK_BUFFER);
  tft.clearScreen(ACTIVE_BACK_BUFFER, COLOR65K_BLACK);
  tft.selectExternalFont(RA8876_FONT_FAMILY_ARIAL, RA8876_FONT_SIZE_24, RA8876_FONT_ENCODING_ASCII);
  tft.setTextScale(1);
  tft.drawRect(0, 599, 1023, 0, COLOR65K_WHITE);
  tft.drawLine(0, 300, 1023, 300, COLOR65K_WHITE);
  tft.drawLine(341, 0, 341, 300, COLOR65K_WHITE);
  tft.drawLine(341 * 2, 0, 341 * 2, 300, COLOR65K_WHITE);
  tft.textColor(COLOR65K_RED, COLOR65K_BLACK);
  tft.putString(10, 310, "4,0 V");
  tft.putString(10, 335, "3,8 V");
  tft.textColor(COLOR65K_GREEN, COLOR65K_BLACK);
  tft.putString(10, 360, "3,6 V");
  tft.putString(10, 385, "3,4 V");
  tft.putString(10, 410, "3,2 V");
  tft.putString(10, 435, "3,0 V");
  tft.putString(10, 460, "2,8 V");
  tft.putString(10, 485, "2,6 V");
  tft.putString(10, 510, "2,4 V");
  tft.putString(10, 535, "2,2 V");
  tft.putString(958, 310, "4,0 V");
  tft.putString(958, 335, "3,8 V");
  tft.putString(958, 360, "3,6 V");
  tft.putString(958, 385, "3,4 V");
  tft.putString(958, 410, "3,2 V");
  tft.putString(958, 435, "3,0 V");
  tft.putString(958, 460, "2,8 V");
  tft.putString(958, 485, "2,6 V");
  tft.putString(958, 510, "2,4 V");
  tft.putString(958, 535, "2,2 V");
  tft.selectExternalFont(RA8876_FONT_FAMILY_ARIAL, RA8876_FONT_SIZE_32, RA8876_FONT_ENCODING_ASCII);
  tft.putString(txtColumn1, txtLine1, "Solar Charger");
  tft.putString(txtColumn1, txtLine2, "Charger 1");
  tft.putString(txtColumn1, txtLine3, "Charger 2");
  tft.putString(txtColumn1, txtLine4, "Charger 3");
  tft.putString(txtColumn1, txtLine5, "WattHour Sol");
  tft.putString(txtColumn1, txtLine6, "WattHour 1");
  tft.putString(txtColumn1, txtLine7, "WattHour 2");
  tft.putString(txtColumn1, txtLine8, "WattHour 3");
  tft.putString(txtColumn2, txtLine1, "Main Batt %");
  tft.putString(txtColumn2, txtLine2, "#Act. Chargers");
  tft.putString(txtColumn2, txtLine3, "Main batt Ah");
  tft.putString(txtColumn2, txtLine4, "Main batt V");
  tft.putString(txtColumn2, txtLine5, "12V Batt A");
  tft.putString(txtColumn2, txtLine6, "12V Batt V");
  tft.putString(txtColumn2, txtLine7, "");
  tft.putString(txtColumn2, txtLine8, "");
  tft.putString(txtColumn3, txtLine1, "Outdoor");
  tft.putString(txtColumn3, txtLine2, "Cabin");
  tft.putString(txtColumn3, txtLine3, "Motor cont");
  tft.putString(txtColumn3, txtLine4, "Front Batt");
  tft.putString(txtColumn3, txtLine5, "Bottom Batt");
  tft.putString(txtColumn3, txtLine6, "Rear Batt");
  tft.putString(txtColumn3, txtLine7, "Charger");
  tft.putString(txtColumn3, txtLine8, "DC-DC conv.");
  for (int i = 0; i < NUM_VALUES; i++)
    if (i < 9)
      tft.setCursor(CellBeginL + i * CellSpacing, 575);
      tft.setCursor(CellBeginL - 4 + i * CellSpacing, 575);
    tft.textColor(COLOR65K_WHITE, COLOR65K_BLACK);
    tft.selectExternalFont(RA8876_FONT_FAMILY_ARIAL, RA8876_FONT_SIZE_16, RA8876_FONT_ENCODING_ASCII);
    tft.print(i + 1);
void layout_simple(){
  //Draw charging graphics
  tft.canvasImageStartAddress(ACTIVE_BACK_BUFFER); // Start PAGE 1
  tft.drawRect(256, 150,512, 450, COLOR65K_WHITE);
void update_advanced(){
  layout_advanced();
    //if (CellActive[i] == 1)
      modbus.begin(i, modbusSerial, 2);
      //BOSS: Test CODE CellValue[i] = modbus.uint16FromRegister(0x03, 0, bigEndian);
      CellVoltage[i] = CellValue[i] / Voltage_divider;
      //BOSS: Test CODE
      CellVoltage[i] = 3.6;
#ifdef DEBUG_1
      Serial.print("Reading Cell ");
      Serial.println(i);
      Serial.print("CellValue  = ");
      Serial.println(CellValue[i]);
      Serial.print("CellVoltage  = ");
      Serial.println(CellVoltage[i]);
#endif
  tft.fillRect(txtColumn1 + 220, 10, 340, txtLine8 + 32, COLOR65K_BLACK);
  if (ADC_ChannelEnable[0]){
    //Serial.print("Update Solar Charger ");
    //Serial.print(AmpCompensatedValue[0]);
    //Serial.print(" ");
    //Serial.print(WattHours[0]);
    tft.setCursor(txtColumn1 + 240, txtLine1);
    tft.print(AmpCompensatedValue[0], 1);
    tft.setCursor(txtColumn1 + 240, txtLine5);
    tft.print(WattHours[0], 1);
    //tft.putFloat(txtColumn1 + 240, txtLine1, (float)AmpCompensatedValue[0], 5, 2, "n");
    //tft.putFloat(txtColumn1 + 240, txtLine5, (float)WattHours[0], 5, 2, "n");
  if (ADC_ChannelEnable[1]){
    //Serial.print("Update Charger 1 ");
    //Serial.print(AmpCompensatedValue[1]);
    //Serial.print(WattHours[1]);
    tft.setCursor(txtColumn1 + 240, txtLine2);
    tft.print(AmpCompensatedValue[1], 1);
    tft.setCursor(txtColumn1 + 240, txtLine6);
    tft.print(WattHours[1], 1);
    //tft.putFloat(txtColumn1 + 240, txtLine2, (float)AmpCompensatedValue[1], 5, 2, "n");
    //tft.putFloat(txtColumn1 + 240, txtLine6, (float)WattHours[1], 5, 2, "n");
  if (ADC_ChannelEnable[2]){
    //Serial.print("Update Charger 2 ");
    //Serial.print(AmpCompensatedValue[2]);
    //Serial.print(WattHours[2]);
    tft.setCursor(txtColumn1 + 240, txtLine3);
    tft.print(AmpCompensatedValue[2], 1);
    tft.setCursor(txtColumn1 + 240, txtLine7);
    tft.print(WattHours[2], 1);
    //tft.putFloat(txtColumn1 + 240, txtLine3, (float)AmpCompensatedValue[2], 5, 2, "n");
    //tft.putFloat(txtColumn1 + 240, txtLine7, (float)WattHours[2], 5, 2, "n");
  if (ADC_ChannelEnable[3]){
    //Serial.print("Update Charger 3 ");
    //Serial.print(AmpCompensatedValue[3]);
    //Serial.println(WattHours[3]);
    tft.setCursor(txtColumn1 + 240, txtLine4);
    tft.print(AmpCompensatedValue[3], 1);
    tft.setCursor(txtColumn1 + 240, txtLine8);
    tft.print(WattHours[3], 1);
    //tft.putFloat(txtColumn1 + 240, txtLine4, (float)AmpCompensatedValue[3], 5, 2, "n");
    //tft.putFloat(txtColumn1 + 240, txtLine8, (float)WattHours[3], 5, 2, "n");
  tft.setCursor(txtColumn2 + 250, txtLine4);
  tft.print(TotalVolatageTracktionBattery, 1);
  tft.setCursor(txtColumn2 + 250, txtLine2);
  tft.print(numberOfChargersEnabled, 1);
  tft.setCursor(txtColumn2 + 250, txtLine3);
  tft.print(AmpHoursTotal, 1);
  int color;
    int cell = (int)(CellVoltage[i + 1] * 100);
    topPos = map(cell, 200, 400, 560, 320);
    if (LastDrawnValues != cell)
      tft.fillRect(ColumBegin, topPos, ColumBegin + ColumWidth, ColumBottom, COLOR65K_BLACK);
    if (cell < 250 || cell > 370)
      color = COLOR65K_RED;
      color = COLOR65K_GREEN;
    if( cell > 220 ){
      tft.fillRect(ColumBegin + (i * ColumSpacing), topPos, ColumBegin + ColumWidth + (i * ColumSpacing), ColumBottom, color);
    else{
      tft.fillRect(ColumBegin + (i * ColumSpacing), ColumBottom, ColumBegin + ColumWidth + (i * ColumSpacing), ColumBottom - 2, color);
  tft.setCursor(txtColumn3 + 200, txtLine2);
  tft.print(Cabin_temp);
  sprintf(ClockBuffer, "%02i:%02i:%02i", RTC_Clock_Data.Hour, RTC_Clock_Data.Minute, RTC_Clock_Data.Second);
  tft.putString(txtColumn2, txtLine7, ClockBuffer);
  sprintf(ClockBuffer, "End Chg: %02i:%02i:%02i", endTimeDay, endTimeHour, endTimeMinute);
  tft.putString(txtColumn2, txtLine8, ClockBuffer);
  swap_display();
void update_simple(){
  layout_simple();
  tft.fillRect(256, 150, (unsigned long)RUNTIME % 512, 450, COLOR65K_GREEN);
  swap_display();
void swap_display(){
  if( ACTIVE_FRONT_BUFFER == DOUBLE_BUFFER_1 ){
    ACTIVE_FRONT_BUFFER = DOUBLE_BUFFER_2;
    ACTIVE_BACK_BUFFER  = DOUBLE_BUFFER_1;
    tft.displayImageStartAddress(DOUBLE_BUFFER_2);
    tft.canvasImageStartAddress(DOUBLE_BUFFER_1);
  else{
    tft.displayImageStartAddress(DOUBLE_BUFFER_1);
    tft.canvasImageStartAddress(DOUBLE_BUFFER_2);
int CalculateTimeDifferneceInSeconds(){
  //RTC_Clock_Data.Day
  int daysInSeconds = 0;
  int hoursInSeconds = 0;
  int minsInSeconds = 0;
  if( RTC_Clock_Data.Day > endTimeDay ){
    daysInSeconds = (endTimeDay + 7 - RTC_Clock_Data.weekday())*24*60*60;
  else{
    daysInSeconds = (endTimeDay - RTC_Clock_Data.weekday())*24*60*60;
  if( RTC_Clock_Data.Hour > endTimeHour ){
    hoursInSeconds = (endTimeHour + 24 - RTC_Clock_Data.Hour)*60*60;
  else{
    hoursInSeconds = (endTimeHour - RTC_Clock_Data.Hour)*60*60;
  if(  RTC_Clock_Data.Minute > endTimeMinute ){
    minsInSeconds = (endTimeMinute + 60 - RTC_Clock_Data.Minute)*60;
  else{
    minsInSeconds = (endTimeMinute - RTC_Clock_Data.Minute)*60;
  Serial.print("Time Difference: ");
  Serial.println(daysInSeconds + hoursInSeconds + minsInSeconds);
  return daysInSeconds + hoursInSeconds + minsInSeconds;
void SetChargerAndDutyCycle( int secondsToFinish, int missingAmpHours, int maxChargeingCapability){
  Serial.println("secondsToFinish : missingAmpHours : maxChargeingCapability");
  Serial.print(secondsToFinish);
  Serial.print(" ");
  Serial.print(missingAmpHours);
  Serial.print(" ");
  Serial.println(maxChargeingCapability);
  double charging_fraction = ((double)missingAmpHours/(double)secondsToFinish )/(double)maxChargeingCapability;
  tft.println("charging_fraction");
  tft.println(charging_fraction);
  if( charging_fraction < 0.33){
    numberOfChargersEnabled = 1;
    chargersDutyCyclePercent = 100*charging_fraction * 3.0;
  else if(  charging_fraction < 0.66){
    numberOfChargersEnabled = 2;
    chargersDutyCyclePercent = 100*charging_fraction * 3.0/2.0;
  else{
    numberOfChargersEnabled = 3;
    chargersDutyCyclePercent = 100*charging_fraction;
void EverySecond(){
  update_RUNTIME();
  //Turn on LED while in service routine
  digitalWrite(13, 1);
  if (Device64Active == 1)
    update_ADC_Values(64);
  if (Device65Active == 1)
    update_ADC_Values(65);
  if (RTC.read(RTC_Clock_Data)) {
    //BOSS: Update the time in the display
  else {
    if (RTC.chipPresent()) {
      Serial.println("The DS1307 is stopped.  Please run the SetTime");
      Serial.println("example to initialize the time and begin running.");
      Serial.println();
      Serial.println("DS1307 read error!  Please check the circuitry.");
      Serial.println();
    TotalVolatageTracktionBattery += CellVoltage[i];
  ChargerPreviouslyConnected = ChargerConnected;
  if( digitalRead(CHARGER_CONNECTED) && ChargerPreviouslyConnected == 0){
    DoFullCharge = true;
  ChargerConnected = digitalRead(CHARGER_CONNECTED);
  #ifdef DEBUG_2
  Serial.println("AmpHoursTotal < MAX_AMP_HOURS: ");
  Serial.print(AmpHoursTotal);
  Serial.print( " " );
  Serial.print(MAX_AMP_HOURS);
  Serial.println(AmpHoursTotal < MAX_AMP_HOURS);
  Serial.println("ChargingPWMIndex : chargersDutyCyclePercent : numberOfChargersEnabled : DoFullCharge");
  Serial.print(ChargingPWMIndex);
  Serial.print(chargersDutyCyclePercent);
  Serial.print(numberOfChargersEnabled);
  Serial.println(DoFullCharge);
  #endif
  if( ChargerConnected ){
    Serial.print( " ChargerConnected " );
    if( AmpHoursTotal < MAX_AMP_HOURS){
      Serial.println( " AmpHoursTotal < MAX_AMP_HOURS " );
      if( DoFullCharge ){
        Serial.println( " DoFullCharge " );
        numberOfChargersEnabled = 4;
        chargersDutyCyclePercent = 100;
      else{
        Serial.println( " !DoFullCharge  -> SetChargerAndDutyCycle" );
        SetChargerAndDutyCycle( CalculateTimeDifferneceInSeconds(), MAX_AMP_HOURS - AmpHoursTotal, AmpCompensatedValue[0] + AmpCompensatedValue[1] + AmpCompensatedValue[2] + AmpCompensatedValue[3]  );
    else{
      Serial.println( " All chargers OFF!!!!!!!---------------------- " );
      digitalWrite( CHARGE_WIRE_ENABLE_1, LOW );
      digitalWrite( CHARGE_WIRE_ENABLE_2, LOW );
      digitalWrite( CHARGE_WIRE_ENABLE_3, LOW );
      digitalWrite( CHARGE_SOLAR_ENABLE_1, LOW );
  else{
  Watchdog.reset();
  update_advanced();
void Every10Seconds(){
  digitalWrite(4, 1);
  digitalWrite(4, 0);
void EveryMinute(){
  //Enviromental Sensor code.
  OutsideTemp = (ds.getTempC());
  bme.read(Cabin_barometric_presure, Cabin_temp, Cabin_humidity);
  Blynk.virtualWrite(V0, Cabin_temp);
  Blynk.virtualWrite(V1, Cabin_barometric_presure);
  Blynk.virtualWrite(V2, Cabin_humidity);
  Blynk.virtualWrite(V7, OutsideTemp);
  if( AmpHoursTotal < MAX_AMP_HOURS && (ChargingPWMIndex < chargersDutyCyclePercent || DoFullCharge)  ){
    if( DoFullCharge ){
      digitalWrite(CHARGE_WIRE_ENABLE_1, HIGH);
      digitalWrite(CHARGE_WIRE_ENABLE_2, HIGH);
      digitalWrite(CHARGE_WIRE_ENABLE_3, HIGH);
      digitalWrite(CHARGE_SOLAR_ENABLE_1, HIGH);
    else{
      if( numberOfChargersEnabled == 1 ){
        Serial.println( " 1 chargers ON---------------------- " );
      else if( numberOfChargersEnabled == 2){
        Serial.println( " 2 chargers ON---------------------- " );
      else if( numberOfChargersEnabled == 3){
        Serial.println( " 3 chargers ON---------------------- " );
      else{
        digitalWrite(CHARGE_WIRE_ENABLE_1, LOW);
        digitalWrite(CHARGE_WIRE_ENABLE_2, LOW);
        digitalWrite(CHARGE_WIRE_ENABLE_3, LOW);
        digitalWrite(CHARGE_SOLAR_ENABLE_1, LOW);
  else{
  ChargingPWMIndex +=10;
  if( ChargingPWMIndex >= 100 ){
void update_RUNTIME(){
  unsigned long msec = millis();
  //Serial.print("Milis: ");
  //Serial.println(msec);
  double minutes = ((double)msec / 1000.0) / 60.0;
  RUNTIME = minutes / 60.0;
void setup(){
  Wire.begin();   //Startup i2c BUS, Default)(0)
  SPI.setSCK(14); //Set SPI clock to Pin14 insted of Pin13 (default)
  modbusSerial.begin(57600);
  delay(100);
  Serial.println("Starting up...");
  pinMode(RA8876_BACKLIGHT, OUTPUT);    // Set backlight pin to OUTPUT mode
  digitalWrite(RA8876_BACKLIGHT, HIGH); // Turn on backlight
  if (!tft.init())
    Serial.println("Could not initialize RA8876");
  tft.initExternalFontRom(0, RA8876_FONT_ROM_GT30L32S4W); // GT30L16U2W connected to SPI interface 0
  Serial.println("Clearing double buffers");
  tft.clearScreen(DOUBLE_BUFFER_1, COLOR65K_WHITE);
  tft.clearScreen(DOUBLE_BUFFER_2, COLOR65K_RED);
  Serial.println("RA8876 Startup complete...");
  Serial.println("Reading SD card init file");
  pinMode(SD_SELECT, OUTPUT);
  digitalWrite(SD_SELECT, HIGH); // disable SD card
  const size_t bufferLen = 127;
  char buffer[bufferLen];
  const char *filename = "/BMS.ini";
  SPI.begin();
  if (!SD.begin(SD_SELECT)){
    while (1) Serial.println("SD.begin() failed");
  IniFile ini(filename);
  if (!ini.open())
    Serial.print("Ini file ");
    Serial.print(filename);
    Serial.println(" does not exist");
    // Cannot do anything else
    while (1){}
  Serial.println("SD Ini file exists");
  char SlaveString[18];
    if (i < 10)
      sprintf(SlaveString, "Battery Slave #0%i", i);
      sprintf(SlaveString, "Battery Slave #%i", i);
    if (ini.getValue("Slave Units", SlaveString, buffer, bufferLen))
      Serial.print("section 'Slave Units' has an entry 'Battery Slave ");
      Serial.print(i);
      Serial.print(" with value ");
      CellActive[i] = atoi(buffer);
      Serial.println(CellActive[i]);
      Serial.print("Could not read 'Battery Slave #");
      Serial.print(i);
      Serial.print("' from section 'Slave Units', error was ");
      printErrorMessage(ini.getError());
    if (i < 10)
      sprintf(SlaveString, "Bleed #0%i", i);
      sprintf(SlaveString, "Bleed #%i", i);
    if (ini.getValue("Battery Bleed Values", SlaveString, buffer, bufferLen))
      Serial.print("section 'Battery Bleed Values' has an entry 'Bleed ");
      Serial.print(i);
      BleedValues[i] = atoi(buffer);
      Serial.println(BleedValues[i]);
      Serial.print("Could not read 'Bleed #");
      Serial.print(i);
      Serial.print("' from section 'Battery Bleed Values', error was ");
  if( ini.getValue("Battery Info", "Battery Max Charge Capacity mAmp Hours", buffer, bufferLen)){
    BatteryMaxMiliAmpHours = atoi(buffer);
    Serial.print("Could not read 'Battery Max Charge Capacity' from section 'Battery Info', error was ");
  if( ini.getValue("Battery Info", "Charger Max mAmp Output", buffer, bufferLen)){
    ChargerMaxMiliAmpOutput = atoi(buffer);
    Serial.print("Could not read 'Charger Max mAmp Output' from section 'Battery Info', error was ");
  if (ini.getValue("Slave Units", "Current Slave #65", buffer, bufferLen))
    Serial.print("section 'Slave Units' has an entry 'Current Slave #65' with value ");
    Device65Active = atoi(buffer);
    Serial.println(Device65Active);
    char enableBuffer[30];
    char sensitivityBuffer[30];
    char zeroBuffer[30];
      sprintf(enableBuffer, "ADC%i channel enable", i + 1);
      ini.getValue("Current Slave #65", sensitivityBuffer, buffer, bufferLen);
      Serial.print("section 'Current sensor data' has an entry 'ADC Enable");
      Serial.print(i + 1);
      Serial.print(" sensitivity' with value ");
      ADC_ChannelEnable[i] = atoi(buffer);
      Serial.println(ADC_ChannelEnable[i]);
      sprintf(sensitivityBuffer, "ADC%i sensitivity", i + 1);
      Serial.print("section 'Current sensor data' has an entry 'ADC");
      ADC_Sensitivity[i] = atoi(buffer);
      Serial.println(ADC_Sensitivity[i]);
      sprintf(zeroBuffer, "ADC%i ZERO Volt", i + 1);
      ini.getValue("Current Slave #65", zeroBuffer, buffer, bufferLen);
      Serial.print(" ZERO Volt' with value ");
      ADC_ZERO_Volt[i] = atoi(buffer);
      Serial.println(ADC_ZERO_Volt[i]);
    Serial.print("Could not read 'Current Slave #65' from section 'Slave Units', error was ");
  SerialMon.begin(115200);
  // Set GSM module baud rate
  SerialAT.begin(115200);
  delay(3000);
  SerialMon.println("Initializing modem...");
  modem.restart();
  String modemInfo = modem.getModemInfo();
  SerialMon.print("Modem: ");
  SerialMon.println(modemInfo);
  //modem.simUnlock("1066");
  modem.setPreferredMode(3);
  Blynk.begin(auth, modem, apn, user, pass); //Startup BLYNK
  tft.canvasImageStartAddress(ACTIVE_FRONT_BUFFER); //Start PAGE 1
  Timer1Second.begin(EverySecond, 1000000);
  Timer10Second.begin(Every10Seconds, 10000000);
  Timer60Second.begin(EveryMinute, 60000000);
  pinMode(CHARGER_CONNECTED, INPUT);
  pinMode(CHARGE_WIRE_ENABLE_1, OUTPUT);
  pinMode(CHARGE_WIRE_ENABLE_2, OUTPUT);
  pinMode(CHARGE_WIRE_ENABLE_3, OUTPUT);
  pinMode(CHARGE_SOLAR_ENABLE_1, OUTPUT);
  set_BLEED_Values();
  Watchdog.enable(10000);
  Serial.print("Enabled the watchdog");
void loop(){
  Watchdog.reset();
Br Rasmus
Hi Rasmus,
Thanks for sharing your code, its very helpfull.
P.S. You better hide the auth code. :wink:
Regards Chris
Yes, I have changed wi-fi, and blynk token yesterday.
Hopy that
you could use some of the code.
Br Rasmus
How can i get the sim 7000’s library?
Hi chris,
How can i get the sim7000’s library for Blynk?
