Hello, I am having this issue with my project, whenever i run my Peacefair PZEM-004T V3 Energy Monitor along side my blynk, it doesnt read values , but if i end up commenting out or removing the " Blynk.begin(auth, ssid, pass);" line it works fine. any help or assistance would be appreciated.
This is my code below.
#include <PZEM004Tv30.h>
unsigned long previousMillis = 0; // stores the last time the method was called
const long interval = 5000; // the interval (in milliseconds) at which to call the method
float sample = 10;
//#define BLYNK_TEMPLATE_ID "TMPL2AYCIphoL"
PZEM004Tv30 pzem(D2, D1);
bool notifiedUser = false;
char auth[] = "auth_key";
char ssid[] = "WiFI";
char pass[] = "password";
int ledPin = D4;
BLYNK_WRITE(V1) // This is the virtual pin number of the button widget
int buttonState = param.asInt();
if (buttonState == 1) {
digitalWrite(ledPin, HIGH); // turn the LED on
digitalWrite(ledPin, LOW); // turn the LED off
pinMode(ledPin, OUTPUT);
Blynk.virtualWrite(V2, sample);
unsigned long currentMillis = millis();
if (currentMillis - previousMillis >= interval) {
pzSensor();
void pzSensor(){
float voltage = pzem.voltage();
if(voltage != NAN){
if(String(voltage) == "nan"){
else{
Serial.print("Voltage: ");
Serial.print(voltage);
Serial.println("V");
Serial.println("Error reading voltage");
float current = pzem.current();
if(current != NAN){
Serial.print("Current: ");
Serial.print(current);
Serial.println("A");
Serial.println("Error reading current");
Serial.println();
> Blockquote
This is a Blynk Legacy sketch. Are you running a Blynk Legacy local server on your network, or are you using Blynk IoT?
If you are using Blynk IoT then have you deliberately excluded these three lines from your sketch for security reasons…
/* Fill-in information from Blynk Device Info here */
#define BLYNK_TEMPLATE_ID "REDACTED"
#define BLYNK_TEMPLATE_NAME "REDACTED"
#define BLYNK_AUTH_TOKEN "REDACTED"
What version of the Blynk library do you have installed?
I’d suggest that you post your full sketch with sensitive information redacted, along with the output from your serial monitor (copy/paste the text and use triple backticks as if you were posting code).
int ledPin = D4;
// SoftwareSerial pins
#define RX_PIN D6
#define TX_PIN D7
#define BLYNK_TEMPLATE_ID "**********"
#define BLYNK_TEMPLATE_NAME "***********"
SoftwareSerial EspSerial(RX_PIN, TX_PIN); // Create a SoftwareSerial object for serial communication
char auth[] = "***********************************";
char ssid[] = "*************";
char pass[] = "*********";
Serial.begin(9600); // Initialize serial communication with the PC
Blynk.begin(auth, ssid, pass); // Connect to Blynk using the WiFi object
// Set a timed task to send a value to the Blynk app every 5 seconds
timer.setInterval(5000, sendValue);
pinMode(ledPin, HIGH);
Blynk.run(); // Run the Blynk library
timer.run(); // Run the BlynkTimer object
void sendValue() {
int value = random(0, 100); // Generate a random value between 0 and 100
pzSensor();
//Serial.print("Sending value: ");
//Serial.println(voltage);
Blynk.virtualWrite(V2, value); // Send the value to the Blynk app
void pzSensor(){
if(voltage != NAN){
else{
if(current != NAN){
It doesn’t need to be at the top with library version 1.2.0 because it now defaults to connecting to the IoT servers rather than the decommissioned Legacy servers.
It’s still a good idea to have have this, along with the auth token, at the top of the sketch, because it makes pasting the copied values easier.
Where are you getting the auth token from?
Blynk provides you with three lines of firmware configuration code, which includes the auth token, assigned to a variable called BLYNK_AUTH_TOKEN, in the Device Info tab of the web console.
The idea is that you copy/paste these to the top of your sketch, then change this line of code…
to this…
Blynk.begin(BLYNK_AUTH_TOKEN, ssid, pass); // Connect to Blynk using the WiFi object
