I see problem in the MQTT.loop() function
#include <PubSubClient.h>
WiFiClient c;
const char* mqtt_server;
int mqtt_port;
const char* mqtt_user;
const char* mqtt_pass;
PubSubClient MQTT(mqtt_server,mqtt_port,[](char * tp, byte * nd,unsigned int l ){},c);
mqtt_server = "postman.cloudmqtt.com";
mqtt_port = 13033;
mqtt_user = "xxxx";
mqtt_pass = "xxxx";
WiFi.begin("test2","xxxx");
while(WiFi.status()!=WL_CONNECTED)
Serial.print(".");
delay(100);
MQTT.setServer(mqtt_server,mqtt_port);
MQTT.connect("test",mqtt_user,mqtt_pass);
MQTT.subscribe("thongbao");
Blynk.config("xxxxxx","abc.com" ,8080);
Blynk.connect();
float t = millis()/1000;
Serial.print("Millis: ");
Serial.println(t);
MQTT.publish("ml",String(t).c_str());
MQTT.loop();
Blynk.virtualWrite(V1, t);
Your void loop is a problem, read this:
Personally, I don’t use MQTT and Blynk code on the same device (except in some very unusual circumstances). I prefer to use Node-Red with the Blynk.ws contrib plugin, and just run MQTT code on my ESP devices.
Thank you very much !
I edited again code, it run pefect
WiFiClient c;
int mqtt_port;
//PubSubClient MQTT(mqtt_server,mqtt_port,[](char * tp, byte * nd,unsigned int l ){},c);
void nhandl(char* tp, byte* nd, unsigned int length)
String topic(tp);
String noidung= String((char*)nd);
noidung.remove(length);
Serial.print("Have new msg from topic "); Serial.print(topic);
Serial.print(": ");
Serial.println(noidung);
PubSubClient MQTT(mqtt_server,mqtt_port,nhandl,c);
mqtt_port = 13033;
mqtt_user = "xxx";
mqtt_pass = "xxx";
timer.setInterval(2000L, senddata);
Serial.print(".");
delay(100);
MQTT.connect("Pzem004t",mqtt_user,mqtt_pass);
MQTT.subscribe("nd");
Blynk.config("you_auth","abc.com" ,8080);
Blynk.connect();
void senddata()
Serial.println(t,0);
MQTT.publish("ml",String(t,0).c_str());
if (!MQTT.connected())
if (MQTT.connect("Pzem004t",mqtt_user,mqtt_pass))
Serial.println("Connected");
MQTT.publish("tb",String("Connected").c_str());
Serial.print("Error:, rc=");
Serial.print(MQTT.state());
Serial.println(" try again in 3 seconds");
MQTT.loop();
